Posted August 1, 200618 yr comment_176731 I am about to replace my water pump due to a JTR radiator change and while I'm all apart and drained I figured just replace the water pump at the same time. ( I hope for no broken bolts :dead: ) Where can I get some new bolts for this project? I know nissan will have them but I want something stainless. Could I just stop by the local Home Depot and pick up some there or should I order some. If so where should I order these from? Thanks Link to comment https://www.classiczcars.com/forums/topic/21028-new-water-pump-bolts/ Share on other sites More sharing options...
August 1, 200618 yr comment_176740 You can try http://www.zcarcreations.com/ they don't list any water pump bolts but a phone call might get you a step closer.FYI Home depot has very little to choose from when it comes to S/S. Especially metric. Try looking in your phone book for a place that specializes in bolts. And worse case scenario you replace with new oem from the dealer, use plenty of anti-seize on them threads.http://www.zcarcreations.com/Edit; use second link, first one doesn't work. Link to comment https://www.classiczcars.com/forums/topic/21028-new-water-pump-bolts/#findComment-176740 Share on other sites More sharing options...
August 1, 200618 yr Author comment_176748 I plan on using plenty of anti-seize. I will give them a call on the bolts. I guess if all else fails I will head over to nissan. Thanks Ed Link to comment https://www.classiczcars.com/forums/topic/21028-new-water-pump-bolts/#findComment-176748 Share on other sites More sharing options...
August 1, 200618 yr comment_176750 use second link, first one doesn't work.So fix it you silly man! You have a (,)comma after the www rather then a (.)period. Link to comment https://www.classiczcars.com/forums/topic/21028-new-water-pump-bolts/#findComment-176750 Share on other sites More sharing options...
August 1, 200618 yr comment_176751 FWIW, I have found a good selection of stainless hardware at(surprisingly enough) my local ACE hardware store. Another place you could try is www.westmarine.com. I used to work for them and because they are a marine parts outfit they have mucho stainless stuff. Look under fasteners. Hope this helps.Mike Link to comment https://www.classiczcars.com/forums/topic/21028-new-water-pump-bolts/#findComment-176751 Share on other sites More sharing options...
