Email logins are now active ×
Water pump screeching?
TomoHawk
On my 83 na it would squeak a little on cold days. Finally got tired of that took up little more tension on belt problem go away.
Also have heard that the viscous clutch on the cooling fan sounds like that also. Not sure which years had the viscous clutch. apparently you can take the thing apart once you get it off the vehicle and replace the fluid in there.
He's already solved it. On a 83 or any Z with factory air and/or power steering which rules out anything prior to 1979, you could also get a squeal from one of the idler pulley/belt tensioners. The viscous clutch is on basically all Z's (originally)and most other cars as well. Replacing the fluid can be done but it's easier to just replace the fan clutch. I've done it both ways with mixed results as I don't think the fluid (oil) you can buy now days is the same as what Nissan used. That procedure has been discussed a few times on this site.
  • Who's Online   2 Members, 0 Anonymous, 359 Guests (See full list)
