It sounds like your cable is in exactly the same condition as mine... Sorry, I guess I'll just look at getting mine repaired when I finally get the hood open.
Thanks anyways!
No problem!
What is the condition of the engine wiring harness? I have a brother in Huntsville that could possibly pick it up for me.
Really not bad. It had one worn/chafed spot but appears not to be burned. I am getting ready to post the pics and will include some of the harness.
All connectors looked god but some are brittle. The only wires I cut were grounding wires.
Last set of pics for now. The last pic, of the carbs, is why I bought this car. They are not for sale and let's just say I bought the whole car for less than the core charge for the carbs!
I'm looking for the clip that holds the vent cable to the side of the blower fan assembly. On the passenger side of the fresh air/recirculating doohickie (passenger side foot area). There is a cable that comes from the center console. This cable is attached by a small metal clip that snaps in place.
I've drawn a line on one of your pictures to the cable that I'm talking about. I don't need the cable just the clip.
SteveJ - I sell reproduction wiring harness grommets for the 73. If you get the harness and need a grommet let me know. $20 bucks for members.
Cable clips are all in place. Rather than losing one, I cut the cables when removing. It was easier than releasing the clips plus the cables are fairly eaasy to replace.
Hey, I know the dash pad is toast, although I'm looking for one to use as a guniea pig. What would you charge to send me just the pad or the whole dash? Where are you located?
I'm in Bristol, VA.
Thanks
