Posted August 8, 200618 yr comment_177540 DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly painted airplane part you were drying. WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprint whorls and hard-earned guitar calluses in about the time it takes you to say, "Ouch...." ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age. PLIERS: Used to round off bolt heads. HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes. VISE-GRIPS: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand. OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub you want the bearing race out of. WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or 1/2 socket you've been searching for the last 15 minutes. HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new disk brake pads, trapping the jack handle firmly under the bumper. EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering an automobile upward off a hydraulic jack handle. TWEEZERS: A tool for removing wood splinters. PHONE: Tool for calling your neighbors to see if he has another hydraulic floor jack. SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dog **** off your boot. E-Z OUT BOLT AND STUD E XTRACTOR: A tool ten times harder than any known drill bit that snaps off in bolt holes you couldn't use anyway. TWO-TON ENGINE HOIST: A tool for testing the tensile strength on everything you forgot to disconnect. CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large prybar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle. AVIATION METAL SNIPS: See hacksaw. TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under cars at night. Health benefits aside, it's main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading. PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style paper-and-tin oil cans and splash oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads. AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty bolts last over tightened 58 years ago by someone at ERCO, and neatly rounds off their heads. PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part. HOSE CUTTER: A tool used to cut hoses too short. HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts not far from the object we are trying to hit. MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Link to comment https://www.classiczcars.com/forums/topic/21103-do-you-have-these-tools/ Share on other sites More sharing options...
August 8, 200618 yr comment_177558 I've got one you might like to invest in. It's the All in one ratchet special-has every socket you will ever need except for the one that you are looking for. Link to comment https://www.classiczcars.com/forums/topic/21103-do-you-have-these-tools/#findComment-177558 Share on other sites More sharing options...
August 8, 200618 yr comment_177586 Thanks for the laugh! I thought I was the only one with posessed tools. In my case it is a curse from the many times I have left them in a pile on the garage floor rationalizing that I will need them when I come back to my project. Days later when I find time to sneak back out to the garage I find that they have deviously rearanged themselves so now I need a completely different set. A word of caution, don't drink and drill. But think twice before asking your neighbor over to be the designated driller, he may get the wrong impression Steve Link to comment https://www.classiczcars.com/forums/topic/21103-do-you-have-these-tools/#findComment-177586 Share on other sites More sharing options...
August 8, 200618 yr comment_177597 Mike, had to laugh out loud on the wire wheel.......I've had small part literally dissapear from site, not to be found until weeks later while doing the regular garage cleaning. Also, have you ever been working on the wire wheel, finished what you were doing, and then later you sit down and get stabbed by one of the little stands that flew off the wheel that got stuck in your clothes? Ouch!!! Link to comment https://www.classiczcars.com/forums/topic/21103-do-you-have-these-tools/#findComment-177597 Share on other sites More sharing options...
August 8, 200618 yr comment_177607 ROFL Classic! Link to comment https://www.classiczcars.com/forums/topic/21103-do-you-have-these-tools/#findComment-177607 Share on other sites More sharing options...
August 8, 200618 yr comment_177631 LMAO. Great post Mike. So many true things in there. I belive the trouble light is aptly named as that's about it provides...... As for wire wheel comments, I concur on all counts. I am constantly "locating" wire fragments which somhow got tracked inside and embeded themselves strategically in the upright position ready to inflict cruel and unusual punishment on the unsuspecting middle of the night bathroom traveler. OUCH! Link to comment https://www.classiczcars.com/forums/topic/21103-do-you-have-these-tools/#findComment-177631 Share on other sites More sharing options...
August 9, 200618 yr comment_177667 Thanks for the good laugh, unfortunately most of them are true. Link to comment https://www.classiczcars.com/forums/topic/21103-do-you-have-these-tools/#findComment-177667 Share on other sites More sharing options...
