I am looking at a su setup on ebay, item number 140016078700. I know this is a dumb question, but my engine is at work and I cant look to see if it is 2 bolt or a 3 bolt setup. My car is a 73. Will this 3 bolt setup work on my 73? Im not sure if the 73 used both the 2 bolt setup and the 3 bolt setup. If I knew they would work I would consider paying the 275 and buy them now. Any advice??
Thanks in advance.
https://www.classiczcars.com/forums/topic/21130-ebay-su-setup/
  • 4 weeks later...
Snip, I cant look to see if it is 2 bolt or a 3 bolt setup.
The 3 bolt set up that the seller was refering to is the number of screws that hold down the bowl. Earlier 1970's models had the 4 screw set up and the later 71-72 had the 3 screw set up. On your 73 it would not matter. Don't know if you won the auction but what was being sold is a pretty nice set up and looks to be in good condition. Now you won't need to change the intake manifolds to install new carbs as the earlier carbs will bolt up to the 73 manifold. But if you want to clean things up a bit then use the earlier intake manifold and air cleaner.
