no vacuum!!
jmeti000
76 280z with vacuum operated heat/ac controls. however, i have absolutly no vacuum comin or going throught the hoses. my a/c works, but air will blow through the center vents only. other than that i got nothin. ive hooked and unhooked everything i can think of and checked this site over... does anyone know what i need to replace to restore the vacuum to my lines?
yup... i get no flow through the defrosters or the side eyeball vents, and no vaccuum from any of the hoses that go to the control unit. but it blows like mad through the center vents. and it only blows cold air from the a/c, or normal temp air...but no heat. i have vacuum going from the intake to the canister, but no where else. so i checked out these diagrams:
http://www.zcar.com/forums/read.php?f=1&i=545965&t=545965
i pulled the hose from the canister through the firewall and have vacuum through it. the problem is one diagram says that hose goes to a magnet valve, and the other one says it goes straight to the control unit. so instead of contorting my body in strange ways to get under the dash, im gonna try the straight to the control unit first thing in the mornin. btw..i looked for this magnet valve thingy and i dont have a clue what it is or see anything that even resembles it.... anybody know?
Yep yep same deal, though I can get heat, and it seems like I also get flow through the eyeballs sometimes too... 'could be my imagination though.
I can also, sometimes, IF, I'm lucky get it to switch over to the defrost... this has not happened in months though, and I'm beginning to think my getting it to switch over was merely luck.
  • Who's Online   2 Members, 0 Anonymous, 663 Guests (See full list)
