Toby,
As a relatively new member, are you aware of the search function to access the archive of Z info? It has info on just about any mod one would likely do to their Z. Another source is Hybridz's website.....lots of technical info too! To answer your question about the Tokico HP dampers....yes you can use them with a coilover set-up. Also, compared to just lowering springs the coilover set-up provides endless ride height adjustment as well as additional tire/wheel clearance on the inboard side.
