Vacuum from Rocker Cover vent
TomoHawk
Should be located on the bottom of the intake and in the center. Should have a fairly good size rubber hose going from the PCV valve over to the pipe sticking out on the left front side of the engine just behind the front timing cover. PCV hoses are still available from the dealer as well. About $16.00 if I remember correctly.
webdawg1
  • Who's Online   1 Member, 0 Anonymous, 334 Guests (See full list)
