Posted August 18, 200618 yr comment_178931 I did some searching but could not find all the info I needed.1. What type of coil over kits are you guys using?2. Are you happy with the performance of said kits?3. Where is the best place to purchase coil over kits?Thank you for your time and help. I have been on MANY car forums and this has got to be the best one so far! The amount of information that can be found here is priceless. The members aren't bad either!:laugh: Thanks,Thomas Link to comment https://www.classiczcars.com/forums/topic/21232-coil-over-sourcetype/ Share on other sites More sharing options...
August 18, 200618 yr comment_178935 1. Don't use them2. Don't know / refer to # 13. Don't know / Refer to # 1Try this thread http://classiczcars.com/forums/showthread.php?t=22124&highlight=coil+oversor this onehttp://classiczcars.com/forums/search.php Link to comment https://www.classiczcars.com/forums/topic/21232-coil-over-sourcetype/#findComment-178935 Share on other sites More sharing options...
August 20, 200618 yr Author comment_179235 Thankyou master. Thanks for the first link but I really didn't need the second one. I did a good deal of searching. I just didn't find what I was looking for... thats why I posted. Belive me, I have been using the search option on this site quite a bit and there is a ton of info to be found. Sometimes... you just have to post to find exactly what you want. I'm liking the modern motorsports coil over kit with the locking abilities. Thanks again for your help.Thomas Link to comment https://www.classiczcars.com/forums/topic/21232-coil-over-sourcetype/#findComment-179235 Share on other sites More sharing options...
August 20, 200618 yr comment_179255 Ground Control, sectioned struts with Illumina inserts, 8" 250 LBS/inch eibach springs, camber plates, all from ground control.. not difficult to install, and the company was great to work with. performance is what I expected, much firmer than stock, but not overly harsh, worth the bucks. at the 2006 ZCON my car ran an 80.036 in the auto-x, probably in the top 1/5 of all the cars, although I never saw all the results, but was quicker than all my buddies, with no sway bars on 225x16 KDW street tires. Link to comment https://www.classiczcars.com/forums/topic/21232-coil-over-sourcetype/#findComment-179255 Share on other sites More sharing options...
