Does anyone know where I can find a 'pigtail' that the bulb fits in to for the taillight of a 1973 Datsun 240Z? Mine broke when I tried to take the bulb out, it was so rusted. If I cannot find a pigtail, where can I get a harness for the rear taillight assembly. Appreciate the help, you helped me before when it came to struts and bushings. Thanks.
  Ed said:
I think they are all the same from 70-73. Look through the classifieds for someone parting out a car. Try Hybridz also. Call your local dismantlers (junkyards).
Nope. The '70 and early '71s are different. I've got both styles. Slight difference in the bulb function, and a different size connector plug. You'll need the ones from 1/71 or later for a '73.
Kirkgz , I think I have a couple of the wiring harness for the tail lights . I'll take a look and see , at least I can come up with a light socket or two . Gary
This is KirkgZ. Thanks to all who offered information on my "pigtail" issue. I have found what I was looking for at zcarsource.com in case anyone else has the same needs, thanks again.
