Posted August 20, 200618 yr comment_179282 Quite a while ago (probably a year ago or better) somebody posted a detailed explanation of how to correctly install a pertronix unit in a 240Z. In searching previous threads, I am unable to locate it. Would somebody be kind enough to point me in the right direction?Devin Link to comment https://www.classiczcars.com/forums/topic/21267-pertronix-install/ Share on other sites More sharing options...
August 20, 200618 yr comment_179284 Bambikiller used to have a post on how to install the pertronix but it seems to have disapeared. The main thing to remember is that the wires on the pertronix are too short, and you have to lengthen them by about 12 inches in order to reach the coil. Other than that, the instructions with the product are okay. Link to comment https://www.classiczcars.com/forums/topic/21267-pertronix-install/#findComment-179284 Share on other sites More sharing options...
August 20, 200618 yr comment_179285 Bambikiller240z posted an article on this installation, but I can't find it either-it was linked from the front page for a while.Will Link to comment https://www.classiczcars.com/forums/topic/21267-pertronix-install/#findComment-179285 Share on other sites More sharing options...
August 20, 200618 yr comment_179286 check out Zhome.com, the pertronix instructions are slightly vague. Link to comment https://www.classiczcars.com/forums/topic/21267-pertronix-install/#findComment-179286 Share on other sites More sharing options...
August 21, 200618 yr comment_179350 I am on the road right now, for most of the week, but Carl had sent me his instructions after his post was deleted. It would be on my home computer. If you need it PM me before Friday. I will not have time on the weekend, this coming weekend. Carl wouldn't mind you getting this personally as he was very helpful. He had other issues. Link to comment https://www.classiczcars.com/forums/topic/21267-pertronix-install/#findComment-179350 Share on other sites More sharing options...
August 21, 200618 yr comment_179365 Why not get it directly from the source?http://www.pertronix.com/downloads/ignitor12vneg.pdfAnd here's a great instruction sheet on installating and electronic ignition hosted by Gavin, one of our members.http://www.viczcar.com/Technical/Dizzy/elecdiz240z.pdf Link to comment https://www.classiczcars.com/forums/topic/21267-pertronix-install/#findComment-179365 Share on other sites More sharing options...
