Well I had fun today at my local Pick & Pull today. I pulled a F54/P79 engine and 5spd out of an 10/80 280ZX 2+2 licensed as an 81 and got the whole thing for $289. I have never pulled an engine before but it was kinda fun. 6 bolts and some hose and wire cutting. Done in 2hrs and that was taking my time.
My plans for it are a mild build up with head and intake manifold port matching, stage 1 or 2 cam and a header. Engine rotates fine and seems to have good compression when turning it via the crank pully bolt. My guess is that it is a running engine since the demise of the car was an impact to the left front quarter panel which bent the unibody and frame rail pretty badly. ODO said 183K miles.
Supposedly the 2+2 got a stronger clutch setup, and is the same as the turbo models, consisting of a different flywheel with a 240mm friction area vs the standard 225mm, and stronger pressure plate with 775lbs? clamping force vs. 550lbs? or something like that. Please feel free to correct these numbers. They are from long term memory and can't find a reference to the figures anywhere.
Now that I have a late FS5C71B, I'll think I need to get back and grab an 3.9 R200, and the moustach bar and half-shafts from a 280Z. I found a 73' that has a swapped R200 so it probably has the bar and shafts I'm looking for. I hope it's there when I go back.
I have a FS5C71A now with a the stock 3.364 R180. My understanding is that the FS5C71AB is geared too high for use with the 3.364 R180. Will someone please confirm or deny this?
https://www.classiczcars.com/forums/topic/21277-woohoo-fun-at-pp/Share on other sites
