You mentioned that looking at the stamp from different angles the numbers could be a P-70 . Well there is a P-79 head . It is from a injected 280ZX If it is a P-90 as was stated before , that came from a 280ZX turbo. One thing , the P-79 has liners showing in the exhaust ports . The P-90 doesn't. Gary
Beandip, After seeing in the daylight it is a P90. How does this compare to an N42 or E88. I would be using it on a L28 with fuel injection or SU's. I have a 73 and 74 with L28's and SU's, also have a 75 and 77 with L28's and fuel injection. Would be using this as a back-up head. Thanks, MC75Z
mc75z , The P-90 if not milled will give you vary low compression on your L-28 , because it has dished pistons and the P-90 is meant to run with a Turbo charger to boost the compression. It is a much better head than the other two you mentioned because it has a better designed combustion chamber and larger valves. If you were using a flat top piston block , 54 , block this would help. So if you have the head milled to boost the compression , it will be a good up grade. Not having done this set up . I am only repeating the information that I have learned . I am running a F-54 block flat topped pistons and a P-79 head , which was for a injected application . There are two different 88 heads , one from a '72z and the other from a '73 which is a emission detuned application with lower compression. Gary
