August 27, 200618 yr comment_180157 When it was stated that you can use the stock coil . Not he 240 coil but the ZX coil and it will be on 12 volts and no resister. Gary Link to comment https://www.classiczcars.com/forums/topic/21339-ignitiontimingcarb-question/?&page=2#findComment-180157 Share on other sites More sharing options...
August 28, 200618 yr comment_180176 If you are using an MSD box, you should be able to eliminate the stock inginition module by running the output of the dizzy's pickup straight into the MSD box. I have a box on order, so haven't done it yet myself, but I've read others say they have, and the MSD instructions show it should support that. Link to comment https://www.classiczcars.com/forums/topic/21339-ignitiontimingcarb-question/?&page=2#findComment-180176 Share on other sites More sharing options...
