Posted August 28, 200618 yr comment_180209 What is the length of the 69-early 71 Driveshaft and the length of the late 71 up driveshaft? Is the automatic different? The measurement I need is center to center of the U-joints. Link to comment https://www.classiczcars.com/forums/topic/21355-drive-shaft-length/ Share on other sites More sharing options...
August 28, 200618 yr comment_180218 Dave, On my early driveshaft I got 21 1/8" from the centers of the two u-joints. I now have the later shaft in there and think it was about an inch longer.?.? I have to get up under there a little today and will see if I can get you that measurement. Link to comment https://www.classiczcars.com/forums/topic/21355-drive-shaft-length/#findComment-180218 Share on other sites More sharing options...
August 28, 200618 yr comment_180220 In the early cars, I don't believe there is any difference between auto and manual driveshafts. I used the auto driveshaft with my Type A four speed when I converted.Do you think you need an early (short) driveshaft, Dave? I should have a spare one soon. Can't vouch for the condition of the u-joints, you'd probably want to replace them. Link to comment https://www.classiczcars.com/forums/topic/21355-drive-shaft-length/#findComment-180220 Share on other sites More sharing options...
August 31, 200618 yr comment_180526 I used a 72 auto drive shaft with a 77 4-speed Link to comment https://www.classiczcars.com/forums/topic/21355-drive-shaft-length/#findComment-180526 Share on other sites More sharing options...
