September 3, 200618 yr comment_180994 My total cost was less than 10 bucks, soldering an shrink wrap is easy, no crimping and in total time it took about a half hour. Link to comment https://www.classiczcars.com/forums/topic/21364-injector-wires/?&page=3#findComment-180994 Share on other sites More sharing options...
September 3, 200618 yr comment_180995 According to the article, each connector was $12, and you need about 8 or so.Maybe soldering for you is easy, but I would expect to spend an hour easy on each connector, and some time to inspect & redo anything else on the injector harness. and that's if the copper wire strands inside are good enough to solder to. That's why I'd go for a newer or assembled harness. With all that extra wire I have coiled up for each injector connector, I would consider cutting the wire to length first and crimping on new terminals like in the article Link to comment https://www.classiczcars.com/forums/topic/21364-injector-wires/?&page=3#findComment-180995 Share on other sites More sharing options...
September 4, 200618 yr comment_181019 I sell the good connectors for way less than $12 each. Holy crap, that's a lot!!!! I wish I could get that much for them. To assemble my connectors takes about 2 minutes each. How you put them in your harness is up to you. Some guys use solder, others use butt-splices. Link to comment https://www.classiczcars.com/forums/topic/21364-injector-wires/?&page=3#findComment-181019 Share on other sites More sharing options...
September 4, 200618 yr comment_181023 Do your injector connectors have the rubber boot & quick-release button on them? Link to comment https://www.classiczcars.com/forums/topic/21364-injector-wires/?&page=3#findComment-181023 Share on other sites More sharing options...
September 4, 200618 yr comment_181024 I sell the good connectors for way less than $12 each. Do your injector connectors have the rubber boot & quick-release button on them? Link to comment https://www.classiczcars.com/forums/topic/21364-injector-wires/?&page=3#findComment-181024 Share on other sites More sharing options...
September 4, 200618 yr comment_181031 I sell the good connectors for way less than $12 each. In other words, do you sell these connectors and boots which are the ones we've been discussing here. I clicked on your link but didn't see them. If you do have them what's your price? Link to comment https://www.classiczcars.com/forums/topic/21364-injector-wires/?&page=3#findComment-181031 Share on other sites More sharing options...
September 4, 200618 yr comment_181032 Sbake01 I bought a brand new pair of 6, and they worked on my car, I bought them off ebay a long time ago for I think $30.00 plus shipping. I think I still have the heat shrink. Link to comment https://www.classiczcars.com/forums/topic/21364-injector-wires/?&page=3#findComment-181032 Share on other sites More sharing options...
September 4, 200618 yr comment_181034 I don't need them. I have plenty. I was just wondering if the one's jmanz6 sells as the "good connectors" are the ones I pictured. The ones I pictured are far better than the OEM regardless of what anyone says. Trust me on that one! I'm the old fart with years of experience with these cars. I'm not looking for advice or endorsement from anyone on these. My cars both have been upgraded to these. Years ago on the 810 and last week on the Z because it really didn't need them up until then. Link to comment https://www.classiczcars.com/forums/topic/21364-injector-wires/?&page=3#findComment-181034 Share on other sites More sharing options...
September 4, 200618 yr comment_181056 If you follow this link http://www.rocketdogmotorsports.com/displayProductDocument.hg?productId=4&categoryId=3it goes the ones I sell that are far superior to the OEM ones. They don't have the boot you think is so great, they have a silicone plug that slides over the wires and presses into the plug body to keep the moisture out. They also have the quick release tabs to allow you to take them off without damaging them. Link to comment https://www.classiczcars.com/forums/topic/21364-injector-wires/?&page=3#findComment-181056 Share on other sites More sharing options...
September 4, 200618 yr comment_181057 Yeah, I hate those clips...., I had a problem a ouple weeks ago with the engine idling at 1500 ALL THE TIME, so when I hunted the problem down, I found that the connector was off the Aux. Air valve.:devious: Link to comment https://www.classiczcars.com/forums/topic/21364-injector-wires/?&page=3#findComment-181057 Share on other sites More sharing options...
September 4, 200618 yr comment_181068 ....They don't have the boot you think is so great...Again, I'm not here to debate the issue, get advice, or endorsement from anyone. I was merely asnwering Tomohawk's question. You like what you like and I like what I like. Nothing wrong with that. Link to comment https://www.classiczcars.com/forums/topic/21364-injector-wires/?&page=3#findComment-181068 Share on other sites More sharing options...
September 4, 200618 yr comment_181074 Wright. I'll head out to the so-called pick-a-part, and see what I can find there. Link to comment https://www.classiczcars.com/forums/topic/21364-injector-wires/?&page=3#findComment-181074 Share on other sites More sharing options...
