September 7, 200618 yr comment_181419 I guess that is not to much of a difference Link to comment https://www.classiczcars.com/forums/topic/21396-grant-steering-wheel-adapter/?&page=2#findComment-181419 Share on other sites More sharing options...
September 13, 200618 yr comment_182263 Mine is the series 1 then. Link to comment https://www.classiczcars.com/forums/topic/21396-grant-steering-wheel-adapter/?&page=2#findComment-182263 Share on other sites More sharing options...
September 13, 200618 yr comment_182282 You need to spend more time in the threads before The Rust seeks vengeance for your blasphomyROFL ! While the 240Z Steering wheels are a combination of resin and wood, they are NOT Walnut! Walnut is not an easily maleable wood even when saturated with resin-or anything else! The OEM shifter know could be Walnut(I have never really checked to see), but not the steering wheel,. The later S30s came with a black closed cell rubber rim made to look like it was covered with a stitched leather cover.Will Sorry, I know this and should have been more careful with my statement. I should have said that all 240Zs came with simulated Walnut steering wheels. Thanks for the slap in the face Will. Link to comment https://www.classiczcars.com/forums/topic/21396-grant-steering-wheel-adapter/?&page=2#findComment-182282 Share on other sites More sharing options...
September 13, 200618 yr comment_182309 Sorry, I know this and should have been more careful with my statement. I should have said that all 240Zs came with simulated Walnut steering wheels. Thanks for the slap in the face Will. [/quoteThat was ment to be a little poke in the ribs, or a lite smack to the back of the head, not a slap in the face! I mean it isn't like you said Goertz designed the 240ZLOL ! Will Link to comment https://www.classiczcars.com/forums/topic/21396-grant-steering-wheel-adapter/?&page=2#findComment-182309 Share on other sites More sharing options...
