Z Excellence Posted September 3, 2006 Share #1 Posted September 3, 2006 On my 76 280Z when I have the AC fan on #4 which is high, after about 10 minutes the motor starts whining. If I hit a bump in the road or turn it down to #3 it will stop whining for awhile.Does this sound like the bearings in the motor going out? If so should I stick to a Nissan replacement or an aftermarket. I don't even know if I can still find a new Nissan. Thanks Link to comment Share on other sites More sharing options...
sblake01 Posted September 3, 2006 Share #2 Posted September 3, 2006 I'd try removing it and cleaning/lubing it first. 74-78 motors produce a pretty good air flow compared to the earlier ones. 27175-U0100 is the number. I purchased one in 2000 from Nissan but I'm not sure if they would still have them. Link to comment Share on other sites More sharing options...
hls30.com Posted September 3, 2006 Share #3 Posted September 3, 2006 Yep your bushings are dry/worn. Lube then and that will take carof the noise for a while. Depending on how long this has been happening and how ;omg the fan has run while howling, it may be time for a new one, or to take the motor to an ALternator/Starter shop fpr a bushing replacement.bearing upgrade. The last time I had one done it was $30 to have bearings put in. the fan was less noisy and put out noticeably more air(even over the output of a non howling fan) as well.Will Link to comment Share on other sites More sharing options...
