Posted September 4, 200618 yr comment_181081 Hello,I had a u-joint go bad in the rear, so in the process of replacing all of them, I came across 2 ring & pinion sets (3.54 & 4.375) for an insanely cheap amount. (one was less than $10!)I finally just got everything back together last night, w/ the 4.375, and took it for a spin. What a difference jumping from my 260z's stock 3.38 made!!! Staying with the r180 over the r200 option also saved me a ton of $$$, since there are none to be found in a junkyard within a 400mile radius, and I'd have to do alot of buying/shipping.One question I do have is, when I had the car up on jack stands, it seemed that only one tire was spinning under load while the other kinda just hung out - not spinning as fast as the other. On the road, I don't feel anything wierd like this...so is this just something that happens with an open diff? Link to comment https://www.classiczcars.com/forums/topic/21437-new-gear-in-the-rear-whoa/ Share on other sites More sharing options...
September 4, 200618 yr comment_181083 ...One question I do have is, when I had the car up on jack stands, it seemed that only one tire was spinning under load while the other kinda just hung out - not spinning as fast as the other. On the road, I don't feel anything wierd like this...so is this just something that happens with an open diff?That's normal operation for a standard differential. Your speedo will be way off with the 4.375 until you change the speedo gear. Your rpm will also increase by about 29% at any given speed. Do you have a 5 speed? Link to comment https://www.classiczcars.com/forums/topic/21437-new-gear-in-the-rear-whoa/#findComment-181083 Share on other sites More sharing options...
September 5, 200618 yr Author comment_181204 I do have a ZX 5 speed in there, and I'm having a hard time locating that speedo gear. Apparently my nissan dealer can only find up to a 19 tooth, which in all fairness I understand since that was the highest they really came with.anyone know of a place to get these? The 21 tooth gear that is. Link to comment https://www.classiczcars.com/forums/topic/21437-new-gear-in-the-rear-whoa/#findComment-181204 Share on other sites More sharing options...
September 5, 200618 yr comment_181208 where is a good place to gt the 4.375? Link to comment https://www.classiczcars.com/forums/topic/21437-new-gear-in-the-rear-whoa/#findComment-181208 Share on other sites More sharing options...
September 5, 200618 yr comment_181218 I do have a ZX 5 speed in there, and I'm having a hard time locating that speedo gear. Apparently my nissan dealer can only find up to a 19 tooth, which in all fairness I understand since that was the highest they really came with.anyone know of a place to get these? The 21 tooth gear that is.Check into gears for the 620/720 pickups and 200SX/HLA10(late 510) 5 speeds. I'm sure that since they were 4 cyl they probably had gears in that range. Link to comment https://www.classiczcars.com/forums/topic/21437-new-gear-in-the-rear-whoa/#findComment-181218 Share on other sites More sharing options...
September 6, 200618 yr Author comment_181342 I thought the 720's may have had it, but the dealership was telling me those ones came in a sleeve of sorts, and had some funky setup that involved a bolt running through the side of them? they could only find a 20 then either...but I'll check on those other models, thanks! Link to comment https://www.classiczcars.com/forums/topic/21437-new-gear-in-the-rear-whoa/#findComment-181342 Share on other sites More sharing options...
September 6, 200618 yr comment_181344 Try this part number: 32703-86401http://www.courtesyparts.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=CP&Product_Code=32703-86401And you'll also need the sleeve: 32707-66300http://www.courtesyparts.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=32707-66300&Category_Code=Be advised that these are listed for the FS5C71B and FSC71B 5 spds. I think they'll work on the FS5W71B but someone chime in here please if they know different. Link to comment https://www.classiczcars.com/forums/topic/21437-new-gear-in-the-rear-whoa/#findComment-181344 Share on other sites More sharing options...
September 8, 200618 yr Author comment_181677 I emailed courtesy with the details of my setup and they said this: "The highest tooth count we have is offered is 19, 18, 17, 16 no 21 though." Link to comment https://www.classiczcars.com/forums/topic/21437-new-gear-in-the-rear-whoa/#findComment-181677 Share on other sites More sharing options...
September 8, 200618 yr comment_181708 Check here: http://www.nissanparts.cc/ Link to comment https://www.classiczcars.com/forums/topic/21437-new-gear-in-the-rear-whoa/#findComment-181708 Share on other sites More sharing options...
