Email logins are now active ×
new gear in the rear = WHOA
4381821
Hello,
I had a u-joint go bad in the rear, so in the process of replacing all of them, I came across 2 ring & pinion sets (3.54 & 4.375) for an insanely cheap amount. (one was less than $10!)
I finally just got everything back together last night, w/ the 4.375, and took it for a spin. What a difference jumping from my 260z's stock 3.38 made!!! Staying with the r180 over the r200 option also saved me a ton of $$$, since there are none to be found in a junkyard within a 400mile radius, and I'd have to do alot of buying/shipping.
One question I do have is, when I had the car up on jack stands, it seemed that only one tire was spinning under load while the other kinda just hung out - not spinning as fast as the other. On the road, I don't feel anything wierd like this...so is this just something that happens with an open diff?
...One question I do have is, when I had the car up on jack stands, it seemed that only one tire was spinning under load while the other kinda just hung out - not spinning as fast as the other. On the road, I don't feel anything wierd like this...so is this just something that happens with an open diff?
That's normal operation for a standard differential. Your speedo will be way off with the 4.375 until you change the speedo gear. Your rpm will also increase by about 29% at any given speed. Do you have a 5 speed?
I do have a ZX 5 speed in there, and I'm having a hard time locating that speedo gear. Apparently my nissan dealer can only find up to a 19 tooth, which in all fairness I understand since that was the highest they really came with.
anyone know of a place to get these? The 21 tooth gear that is.
Check into gears for the 620/720 pickups and 200SX/HLA10(late 510) 5 speeds. I'm sure that since they were 4 cyl they probably had gears in that range.
I thought the 720's may have had it, but the dealership was telling me those ones came in a sleeve of sorts, and had some funky setup that involved a bolt running through the side of them? they could only find a 20 then either...
but I'll check on those other models, thanks!
Try this part number: 32703-86401
http://www.courtesyparts.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=CP&Product_Code=32703-86401
And you'll also need the sleeve: 32707-66300
http://www.courtesyparts.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=32707-66300&Category_Code=
Be advised that these are listed for the FS5C71B and FSC71B 5 spds. I think they'll work on the FS5W71B but someone chime in here please if they know different.
