Posted September 14, 200618 yr comment_182467 I have 76 280z that probably has the original 76 transmission in it.It has lost alot of power and i want to get a better one so my ride would be a bit more smother.Does any one have suggestions on what I should do?-Buy a used Tranny or-Rebuild a used oneany suggestions will help thanks.Ilive in the bay area Link to comment https://www.classiczcars.com/forums/topic/21575-replacing-auto-tranny/ Share on other sites More sharing options...
September 15, 200618 yr comment_182514 if you are near seattle I've got one from an 81zxt that was working when i replaced it with a 5spd. probably bolt to the block ok but drive shaft might be a problem. freebiekrs@whidbey.com Link to comment https://www.classiczcars.com/forums/topic/21575-replacing-auto-tranny/#findComment-182514 Share on other sites More sharing options...
September 21, 200618 yr Author comment_183285 Im in california but thanks anyways Link to comment https://www.classiczcars.com/forums/topic/21575-replacing-auto-tranny/#findComment-183285 Share on other sites More sharing options...
