Opinion needed - use of ES outer tie rod boots
=Enigma=
Does anyone use the urethane outer toe rod boots provided in the Energy Suspension Master kit, or recommend against using them? They seem to fit OK but might fit a little better by cutting a groove on the inner surface to that they actually lock onto small flange on the outter tie rod end. Any comments or experience will be appreciated?
I was a little leery of using them on my 260. They didn't feel like they would stay on without a "snap" fit. But I used them anyway. Once they are tightened down they are a pretty tight fit. Even when filled with grease they appear to be sealed tight. I don't see them being a problem, but I only have about 50 miles on them since replacing all the bushings.
FWIW
Todd
  • Who's Online   1 Member, 0 Anonymous, 341 Guests (See full list)
