cplus Posted September 22, 2006 Share #1 Posted September 22, 2006 Finishing with the engine rebuild and I am looking for opinons for the distributor. I am looking at the Crane XR 3000 Electronic Ignition System and their PS-40 High Performance Coil. Has anyone had any expereince with it? Or should I just get an old Distributor out of a late model and swap with the modual. The system now has a Jacobs electronic points box. I have a liitle paperwork on it but would rather dump the points system. Link to comment Share on other sites More sharing options...
MikeW Posted September 22, 2006 Share #2 Posted September 22, 2006 Have you considered a Pertronix Ignitor? It replaces the points inside of your original distributor and is very easy to install. The only external difference is an extra wire running to the distributor. Link to comment Share on other sites More sharing options...
c david Posted September 22, 2006 Share #3 Posted September 22, 2006 dump the points but use a 79-83 distributor. the money saved will buy a msd and msd brand coil and msd brand wires. if you ignitor goes bad, you can eliminate it as the msd will serve the same funtion.the links below offer a lot of information.cdhttp://www.jrdemers.com/280ZX/distributor/distributor.htmlhttp://www.geocities.com/zgarage2001/engine.html Link to comment Share on other sites More sharing options...
vercingetorix Posted September 22, 2006 Share #4 Posted September 22, 2006 I had an xr3000 with stock distirbutor, getting the eye setup correctly with the rotor was a bit of a pain but it ran O.K.. Later I switched to a 280zx distributor with its built on electronic ignition and it is massively better!! Better power curve, better ignition ,easier starting and the bigger distributor cap prevents high power arcing inside the cap. I think I would spare the expense of the xr3000 and cut to the chase.If you are dead set on the xr3000 I think I still have my complete set up including the distributor somewhere PM me if you're interested.Best, H Houghton Link to comment Share on other sites More sharing options...
cplus Posted September 23, 2006 Author Share #5 Posted September 23, 2006 I think I will go with the 280zx Dist. idea. Do I need a MSD Ignition with it or should I just go with the distributor and the stock modual? Thanks for the help! I am trying to get it together for the Z Fest but I might have to wait till next year. Link to comment Share on other sites More sharing options...
ChrisA Posted September 23, 2006 Share #6 Posted September 23, 2006 Hi Jim, I'm currently running the ZX dizzy (e12-80 module) alone on a 73. Works great. Chris A. Link to comment Share on other sites More sharing options...
Arne Posted September 23, 2006 Share #7 Posted September 23, 2006 Hi Jim, I'm currently running the ZX dizzy (e12-80 module) alone on a 73. Works great. Chris A.Same here on a '71. Link to comment Share on other sites More sharing options...
c david Posted September 23, 2006 Share #8 Posted September 23, 2006 the msd is an upgrade much like changeing the points to an electronic distributor. the msd, coil and wires will allow your car to run far smoother than without. you will get better fuel burn and for me, the car would start in a flash and never use the choke. i have even removed the choke linkage. to answer your question, no you do not need to have an msd but i for one will never run a car without one.cdavid Link to comment Share on other sites More sharing options...
cplus Posted September 25, 2006 Author Share #9 Posted September 25, 2006 Thanks for all the input and help. I am off to find parts! Link to comment Share on other sites More sharing options...
