September 25, 200618 yr comment_183575 Most of the time.... Hi Gary: I had tightened the large nut on the spindle pin puller down... pretty tight.. and the pin didn't move. A friend with more arm power than me... cranked the nut down on the spindle pin puller - until the nut stripped!!.. Spindle pin didn't move... Took the assembly (strut still connected to the lower transverse link)... to the shop and subjected it to 25 Ton's of pressing force... Spindle pin didn't move.... Applied HEAT... to the entire length of the spindle pin... LOTS OF HEAT... put it back in the Press.. and it finally pressed out... Lesson Learned... if the spindle pin puller won't pull it out with "reasonable force" applied to the nut... stop.. apply LOTS OF HEAT... Others that I have done, simply pulled out with no problems... FWIW, Carl B. Carl yours is the first one I have heard of that the puller wouldn't remove. Was the nut and all thread both hardened material and was a bearing used also ? Of course if the pin was so rusted in place that it took much to pull it . I can see why it failed . Link to comment https://www.classiczcars.com/forums/topic/21676-spindle-pin-lock-bolt-question/?&page=2#findComment-183575 Share on other sites More sharing options...
September 25, 200618 yr comment_183638 Carl yours is the first one I have heard of that the puller wouldn't remove. Was the nut and all thread both hardened material and was a bearing used also ? Of course if the pin was so rusted in place that it took much to pull it . I can see why it failed . Hi Gary: I purchased the puller from the source here on the forum and as I understand it - everything is high strength/hardened steel .. and yes that included the thrust bearing. FWIW, Carl B. Link to comment https://www.classiczcars.com/forums/topic/21676-spindle-pin-lock-bolt-question/?&page=2#findComment-183638 Share on other sites More sharing options...
September 25, 200618 yr Author comment_183643 Hey guys...well got the job done and it was easy..no puller needed, just a couple of taps with the rubber mallet and lock bolt popped out and same with the spindle... now the interesting part ....when I bought the car the guy told me he had just replaced all rearend suspension with "poly kit"..no problem he also gave me the rest of the kit to do front suspension etc. what he did, and this is why I originaly started this thread, is he replaced the lock bolt threaded end up(which to my understanding is wrong, correct?) and I also found 2 of the poly bushings crushed and split so they will have to be replaced..he also did the same on the other side(threaded end up). Correct me if I wrong...but from what I read I think I'm right now.... Link to comment https://www.classiczcars.com/forums/topic/21676-spindle-pin-lock-bolt-question/?&page=2#findComment-183643 Share on other sites More sharing options...
September 25, 200618 yr comment_183645 After you take the nut and washer off you should be able to use a small pin punch to get it out. You'll be driving it upwards from the bottom up. snipped...........webdawg1andCarl,You sure you want to stand by that statement about the spindle pin lock bolt? If you drive it "Down" that just wedges it tighter against the spindle pin.....webdawg1Hi webdawg1 (everyone):Based on the fact that Dan S - specified the threaded end of his lock pin as being the "top"... and because he ask of the pin was removed from bottom up and out - - - or top (threaded end) down... I get the distinct impression that his lock pin was installed with the threaded end - up - toward the car body. In that case he would NOT drive the pin "...upwards from the bottom up" as you suggest.From your follow-on replies.. I get the impression that you have it fixed in your mind that all lock pins are always installed with the treaded end down.. toward the road. That has most certainly not been my experience - and based on Dan S's question it would seem to not be the case on his car.If the treaded end is considered to be the top of the lock pin:1. The pin - is wider at the bottom than the top2. You would drive it out by applying pressure to the top of the pin3. If you leave the nut even with the top of the treads - you can safely smack the nut with a brass hammer to dislodge the pin. That is simply a little easier than trying to align a drift with only the threaded end.I'm pretty sure that Dan S understood what I was saying, so I'm sure the pin will come out.I didn't feel that I was contradicting your input - so much as trying to make it clear to Dan S in his terms... and based on his input...... I did say "based on how you (Dan S) ask the question".Sorry for any confusion..Carl B. Link to comment https://www.classiczcars.com/forums/topic/21676-spindle-pin-lock-bolt-question/?&page=2#findComment-183645 Share on other sites More sharing options...
September 25, 200618 yr Author comment_183660 Carl, I completely understood what you were saying...maybe it was just the way I phrased it( canadian accent)...anyways,yes the threaded end was toward the body of the car both sides...and from research I understood the the threaded end was facing the ground, but not in my case....and knowing the pin was tapered I was concerned I might jam it stuck.. To me I would think the threaded end should face the ground since the taper is wider at the other end so in case of loss of nut the taper should keep it wedged in place( I hope ). The only thing I really want is to make sure they are installed correctly.. Link to comment https://www.classiczcars.com/forums/topic/21676-spindle-pin-lock-bolt-question/?&page=2#findComment-183660 Share on other sites More sharing options...
September 25, 200618 yr comment_183663 Carl, I hear ya....a7dz and I have been talking back and forth over the last day or two regarding this (Threaded end Up) (Threaded end Down) thing....seems he (a7dz) has one pin installed facing Down & one facing Up. Bottom line tho in all this is that they are STILL a PAIN to get out..........() Later...... webdawg1 Link to comment https://www.classiczcars.com/forums/topic/21676-spindle-pin-lock-bolt-question/?&page=2#findComment-183663 Share on other sites More sharing options...
September 25, 200618 yr comment_183666 The FSM and the parts CD both show the pin with the threaded end (nut & washer) pointing down towards the ground.FWIWTodd Link to comment https://www.classiczcars.com/forums/topic/21676-spindle-pin-lock-bolt-question/?&page=2#findComment-183666 Share on other sites More sharing options...
September 25, 200618 yr comment_183675 ...snip... Depends on who put the pins back in. Standard practices say that you would put the Keepers in from the top and the nuts on the bottom. So, if the nut failed and came off, the pins would not fall out. ...snip...The Underline identifies Murphy at work.The Bold identifies Fail-Safe methods of maintenance.E Link to comment https://www.classiczcars.com/forums/topic/21676-spindle-pin-lock-bolt-question/?&page=2#findComment-183675 Share on other sites More sharing options...
September 25, 200618 yr comment_183681 I think common sense would tell you to put the threaded end down. That way if for some crazy reason the nut falls off the pin doesn't fall out. Link to comment https://www.classiczcars.com/forums/topic/21676-spindle-pin-lock-bolt-question/?&page=2#findComment-183681 Share on other sites More sharing options...
September 26, 200618 yr comment_183692 I think common sense would tell you...Unfortunately, if "common sense" were indeed, in FACT...COMMON, it would be called INSTINCT. E Link to comment https://www.classiczcars.com/forums/topic/21676-spindle-pin-lock-bolt-question/?&page=2#findComment-183692 Share on other sites More sharing options...
February 7, 200718 yr comment_198491 I've updated the web page with some spindle pin puller pics if anyone is curious...http://www.project280z.com Link to comment https://www.classiczcars.com/forums/topic/21676-spindle-pin-lock-bolt-question/?&page=2#findComment-198491 Share on other sites More sharing options...
February 8, 200718 yr comment_198515 I suppose as a follow-up to all concerned. In the future...should someone respond back to a question about the (Spindle Pin Locking Bolt) and which way it should it be driven out. I suppose the next question to be asked would be "So which way are they facing right now, threaded end Up or Down" and then follow up with "If facing down...Blah Blah Blah" or "If facing up...Blah Blah Blah"Later...webdawg1 Link to comment https://www.classiczcars.com/forums/topic/21676-spindle-pin-lock-bolt-question/?&page=2#findComment-198515 Share on other sites More sharing options...
