Volumetric effecienty at 148% and rising
smokingwheels
yes its me again hi all
Ive been revising the data collected of the past 6 years.
with such improvments i cant go and get some one to test my head flow
i would be giving techonogy away
i will have to build myself a flow rig
case 1
I have a ve of 148% above 2000 RPM
please correct me if im wrong.
ive calculated the air flow against a stocker
1 fill a 60 L garbage bag at idle 4-5 seconds ~.7 cm/min
2 vac secondary main jet flows fuel at ~2000 ~2.96 cm/min
3 deplete fuel supply with single pump delivery ~1.2l/min @6000 ~8.7 cm/min
derated because of its age the book states 1.4 L/min delivery rate, ive measured it at 1.2 L/min
case 2
I have a 7 psi boost for free above 2000
1 reduction in timing of 15 degrees @3000 = .3 deg per kpa boost
approx 50 kpa extra fuel n air is getting in
I know im not getting 210 Kw yet cause the stock exhaust system wont flow 10.35 cm/m ~ 400 cfm so im reasearching that
but the fuel its going in though so i must have a lot of back pressure.
any donations of parts would be put to good use
holley 500,400, 750 , cam, extractors to suite a L20b 4 banger
email me smokingwheels@yahoo.com
you can hear what it sounds like here
I can upload more if needed.
http://www.classiczcars.com/forums/showthread.php?t=18619
cheers
Greg
  • 2 months later...
  • 5 months later...
Yes Ive got way too much time to play
I measured the output of the fuel pump a few months ago
Approx 1 L Min static
So I will have to measure what the carbie holds
Under test I ran out of fuel near the end of 2nd gear ~6000-6500 revs
I reverse Engineered the fuel useage, around 95 hp /L engine displacment
I dont know if its true, dyno places dont want to test a stock engine.
They just laugh, and say Im waisting my money, well the 1/4 mile is cheaper for a few runs anyway and its more realistic.
I read an artical in a mag about ways to inflate/deflate dyno results
1. placement of temp probe, for intake temp
2. use a fast acceleration ramp before mods to obtain lower hp readings
3. use a slow acceleration ramp after mods to improve hp readings
from memory the errors were as high as 50 kw in a 300 kw engine.
So beware of the settings some use to justify the results, I prefer to use the 1/4 mile way
