What have you checked so far? Do all corners light up with the hazards? Do any lights come on with the turn signals (regardless of flashing), have you checked the fuses?
Before anyone will chime in with possible solutions, it would be useful for everyone to know what you have already tried, that way we don't waste your time (or ours) suggesting things that you have already checked.
Have you got a Factory Service Manual (often reffered to as the FSM) or rebuilding guidbook (like haynes or chilton-useful, but far from complete are these)?
And lastly, is this problem with the signals new, or has it been happening for some time?
Burnt fuse.
Loose connection.
Faulty flasher unit. ( hazard switch has seperate flasher unit)
Faulty hazard switch
[turn signals operate when 1 and 2 terminals of harness connector to hazard switch are connected with test lead including 10A fuse].
LARRY
