Posted September 28, 200618 yr comment_183950 I'm trying to do a value adjustment on a 75 280z and unable to loosen the pivot locking nut on the value adjusters. Is there a special tool for this or some trick trick I'm missing. Any help would be appreciated . Andy Link to comment https://www.classiczcars.com/forums/topic/21729-value-adjustment-pivot-locking-nut-problems-on-75-280z/ Share on other sites More sharing options...
September 28, 200618 yr comment_183966 using a wrench on both nuts at the same time has always worked for me, sometimes the really tight ones took a tap or two with a hammer.Will Link to comment https://www.classiczcars.com/forums/topic/21729-value-adjustment-pivot-locking-nut-problems-on-75-280z/#findComment-183966 Share on other sites More sharing options...
