Green ST springs??
BuDavid
I ordered ST springs set for my '77 280Z and they safely arrived.. but the thing is that I noticed in the pictures that the ST springs come in grey color..
I received mine green?? is that right?
I attach a picture of the box and pir of front spring (with sticker) and a rear one..
*other point.. while mounting the springs, do I need a rubber seat (spacer) under the spring? or with lowering spring it is not needed?
yeah you are right about the rubber spacer. I'm confused because one BM guy told me that all springs need that seed, while I don se this part in any z parts resourse!
I know that they share the same color as on the box.. but I saw them grey in internet..
who had same as those in GREEN?
yes David (Montezuma), Juffair roads:sick:
I took your advice, and now I have the whole pakage (KYB struts + integrated boots w. bump stops + ST springs) from shox.com
I think that would be just enough right? well I thaught of aearly moddifaction which is throwing the plastic tie rope which is sopposed to hold the strut boot and use a Stainless steel jubley clip insted so it wont break fom the heat under the car..:smoke:
well that's what I call a heart cooling reply:) so there is no original/duplicate thing here:)
coz when I saw them Green I said to my self, well Mohamed.. u have a paint job to do now! those green springs will look so stupid under your silver Z and it will look like weed lover's carLOL
thanks for the confirmation Bo McCoy..
Vctor, you can be sure that I will, most of the progress is because of this forum andthe help of all of you guys..
I'll report it in "open z car discussion" with photos also! coz I an the opinions of the new rims style..
I hope that the process will take max. 2 weeks coz I need to make a neat job.
I contemplated repainting mine, considering I have a blue/black combo going on with my suspension pieces (blue strut assemblies, t/c rod, steering knuckles; black crossmember and control arm). The pink Tokico springs and green ST sways bars will make it look like a rainbow under my car.
  • Who's Online   1 Member, 0 Anonymous, 598 Guests (See full list)
