Posted October 2, 200618 yr comment_184372 Hey all, Do any of you have a good source for the 10 guage spade connectors under the dash ? I am looking to replace a melted connector and I need to find the male and female spades along with the plastic housings. I am not against going with an aftermarket part, but, I only want the best. The crimp-on cheap-o connectors you can find at the auto parts store won't work for me. I'm thinking about a GM water-tight or equivalent. Link to comment https://www.classiczcars.com/forums/topic/21775-10ga-spade-connectors/ Share on other sites More sharing options...
October 2, 200618 yr comment_184373 Mike;www.waytekwire.comstock numbers:32914 male32915 female Link to comment https://www.classiczcars.com/forums/topic/21775-10ga-spade-connectors/#findComment-184373 Share on other sites More sharing options...
October 2, 200618 yr Author comment_184374 Here's something that is up my alley..http://www.suresealconnections.com/Of course, I would LOVE to find all of the original connectors. Hasn't anyone been down this road? Link to comment https://www.classiczcars.com/forums/topic/21775-10ga-spade-connectors/#findComment-184374 Share on other sites More sharing options...
October 2, 200618 yr comment_184377 Mike;look like this:http://order.waytekwire.com/CGI-BIN/LANSAWEB?WEBEVENT+L0C4C7D765AA58600B2D1072+M37+ENGhttp://order.waytekwire.com/CGI-BIN/LANSAWEB?WEBEVENT+L0C4C7E7859B586002AE1072+M37+ENG Link to comment https://www.classiczcars.com/forums/topic/21775-10ga-spade-connectors/#findComment-184377 Share on other sites More sharing options...
October 2, 200618 yr Author comment_184379 Yipee... I found some good stuff. Funny thing, it was on THIS website. HA!!http://eagleday.stores.yahoo.net/blco.html Link to comment https://www.classiczcars.com/forums/topic/21775-10ga-spade-connectors/#findComment-184379 Share on other sites More sharing options...
October 2, 200618 yr comment_184380 Do you have the special two stage crimper to install those terminals? Link to comment https://www.classiczcars.com/forums/topic/21775-10ga-spade-connectors/#findComment-184380 Share on other sites More sharing options...
October 2, 200618 yr Author comment_184381 Nope... I may have a source for that, but, the tool is likely $100+ Link to comment https://www.classiczcars.com/forums/topic/21775-10ga-spade-connectors/#findComment-184381 Share on other sites More sharing options...
October 2, 200618 yr Author comment_184382 Jim, your links above didn't work. Can you resend them? Link to comment https://www.classiczcars.com/forums/topic/21775-10ga-spade-connectors/#findComment-184382 Share on other sites More sharing options...
October 2, 200618 yr comment_184397 Mike, I do alot of business with Eagleday, mainly for the AMP Fastin-Faston connectors and terminals (like the one you're looking at) and the JIS Bullet connectors (Roadster use these by the bucket full). BTW, this 8mm AMP Fastin-Faston (Spade and Recepticle) is the exact replacement for the main power connectors in the 240Z. I also bought the crimper from them for $30 and It works fine Just want to add this warning - the nylon housings for the the 6.3mm connectors are NOT the same as the ones used in the Datsuns. Except for the 3 position one which does work for the headlight harness connections. Oh yea, of course the 1 position also works, but I think the Z uses only 1 of these in the entire car! Link to comment https://www.classiczcars.com/forums/topic/21775-10ga-spade-connectors/#findComment-184397 Share on other sites More sharing options...
October 2, 200618 yr comment_184399 If you want to go off-spec for a "Better" connector, I have good things to say about the GM Weather-Pac connectors. They just don't look right in a Datsun is the only draw-back.Oh yea, and they're expensive as hell. another point against Link to comment https://www.classiczcars.com/forums/topic/21775-10ga-spade-connectors/#findComment-184399 Share on other sites More sharing options...
