10ga spade connectors?
Mike
Hey all,
Do any of you have a good source for the 10 guage spade connectors under the dash ? I am looking to replace a melted connector and I need to find the male and female spades along with the plastic housings.
I am not against going with an aftermarket part, but, I only want the best. The crimp-on cheap-o connectors you can find at the auto parts store won't work for me. :) I'm thinking about a GM water-tight or equivalent.
Mike, I do alot of business with Eagleday, mainly for the AMP Fastin-Faston connectors and terminals (like the one you're looking at) and the JIS Bullet connectors (Roadster use these by the bucket full).
eagleday_1915_36967070
BTW, this 8mm AMP Fastin-Faston (Spade and Recepticle) is the exact replacement for the main power connectors in the 240Z.
I also bought the crimper from them for $30 and It works fine
eagleday_1911_1569826
Just want to add this warning - the nylon housings for the the 6.3mm connectors are NOT the same as the ones used in the Datsuns. Except for the 3 position one which does work for the headlight harness connections. Oh yea, of course the 1 position also works, but I think the Z uses only 1 of these in the entire car!
  • Who's Online   1 Member, 0 Anonymous, 847 Guests (See full list)
