Posted October 4, 200618 yr comment_184578 Does anyone have the solid bronze rewinds, and if so, do you have any pictures handy of a straight wide shot so I can do some photo chopping to see which look better on my brown 240z? Solid Bronze or sold gold. Link to comment https://www.classiczcars.com/forums/topic/21798-solid-bronze-konig-rewinds/ Share on other sites More sharing options...
October 4, 200618 yr comment_184583 I found this one on a google search, but the lighting is bad. Zak Link to comment https://www.classiczcars.com/forums/topic/21798-solid-bronze-konig-rewinds/#findComment-184583 Share on other sites More sharing options...
October 4, 200618 yr Author comment_184606 Yep, been there, Googled that. I was hoping for something more head on and mounted but I'm afraid that the best I'm gonna get. At any rate, I've decided to go with my first instinct with the solid gold rims at this point, besides, tehy shipped already. I'll post pics when they arrive. It may be a few weeks before I get them mounted. Link to comment https://www.classiczcars.com/forums/topic/21798-solid-bronze-konig-rewinds/#findComment-184606 Share on other sites More sharing options...
October 5, 200618 yr Author comment_184871 Santa came early! I went with gold rather then bronze. They should look nice with the brown paint and gold pin stripes. I also purchased the lug and stem kit along with the wheels, but it turned out that they are the tuner lugs and don't seem to fit the taper of the mounting holes very well. Certainly not like a full acorn style lug which has a larger tapered surface. Gabriel says it's not an issue but I am skeptical. Anyone else feel this way or have any issues with this? Link to comment https://www.classiczcars.com/forums/topic/21798-solid-bronze-konig-rewinds/#findComment-184871 Share on other sites More sharing options...
October 5, 200618 yr comment_184872 Adam, can you please measure (as accurately as possible) the diameter of the center hole for me? Link to comment https://www.classiczcars.com/forums/topic/21798-solid-bronze-konig-rewinds/#findComment-184872 Share on other sites More sharing options...
October 5, 200618 yr Author comment_184874 Update!!! The counterbore is roughly 68mm depending on where you measure from. The measurement I took was using a flat edge and done by eye as 2-21/32" which works out to 2.656" or 67.468mm on the most narrow part of the hole, which is kind of hard to gauge. Update: I attached a better pic from the SLR. Link to comment https://www.classiczcars.com/forums/topic/21798-solid-bronze-konig-rewinds/#findComment-184874 Share on other sites More sharing options...
October 5, 200618 yr comment_184875 Thank you! Link to comment https://www.classiczcars.com/forums/topic/21798-solid-bronze-konig-rewinds/#findComment-184875 Share on other sites More sharing options...
October 5, 200618 yr comment_184880 Adam,I would probably err on the side of safety and use the factory Nissan acorn lug nuts. They are a bit pricey at between $3 and $4 each (if you go with the closed acorn and not the open) but hold up for a much longer period of time. Believe me with the various Enkei 92's that I have used over the years and experimenting with Nissan and aftermarket the Nissan ones awlays seem to win. Look forward to seeing those wheels on your 240Z. That look might be nice on one of my maroon Z's as well or even the silver 240Z if it ever gets running again. Link to comment https://www.classiczcars.com/forums/topic/21798-solid-bronze-konig-rewinds/#findComment-184880 Share on other sites More sharing options...
October 5, 200618 yr comment_184887 My favorite acorn lug nuts are made by McGard, like the locks. Not easy to find, but they guarantee they will never rust, even if you use air tools on them. (Which you should never do, of course.) Probably no more expensive than the Nissan nuts. Link to comment https://www.classiczcars.com/forums/topic/21798-solid-bronze-konig-rewinds/#findComment-184887 Share on other sites More sharing options...
October 6, 200618 yr Author comment_184915 Nice! I love the gold tuner kit w/locks. It looks like Summit has them for $75. Should look nice withe the gold rims and they may even have a larger taper area than the ones I got from Gabriel and hopefully a better fit. Link to comment https://www.classiczcars.com/forums/topic/21798-solid-bronze-konig-rewinds/#findComment-184915 Share on other sites More sharing options...
