Email logins are now active ×
Easiest way to get the driveshaft and halfshafts off the diff
Hrududu
Hey guys, I just have a quick question. What is the easiest way to diconnect the halfshafts and driveshaft so I can replace my diff unit? What are the best tools to use? If there is a way to cheat so i can dimantle as little as possible, that would be great. Im just swapping my existing differential with a new one.
In the following order:
Disconnect driveshaft from pinion. (4 bolts)
Disconnect each halfshaft from the diff. (4 bolts each side)
Remove nuts holding rear of diff to moustache bar. (2 nuts)
Support diff with jack or similar.
Remove front diff crossmember. (4 bolts)
Lower diff and unbolt front mount from crossmember.
Thanks all for the input. Got the new one in and the old one out. I posted a few pics so you can see what I did to the old one. That little metal shaft thingy is busted. Idk what its called or what all else is broken, but it doesn't turn very smooth at all.
The fact that you know where you run at all probably explains it!! LOL I don't think these diffs like drag racing...
Actually thats exactly why :) Im pretty sure i broke it when i ran it at the strip last October. Only 3 runs though :P
  • Who's Online   1 Member, 0 Anonymous, 438 Guests (See full list)
