Posted October 5, 200618 yr comment_184862 Am ready to install a new oil pump in my 280Z but my manual does not go into detail but does talk about the dist. and pos #1 TDC but nothing on where the pump is? is the pump under in the oil pan?thx Raven Link to comment https://www.classiczcars.com/forums/topic/21822-oil-pump-installation/ Share on other sites More sharing options...
October 5, 200618 yr comment_184865 looking at the front of the engine, the pump is on the lower left side. Diagonally across from the distributor. They share a common shaft. Link to comment https://www.classiczcars.com/forums/topic/21822-oil-pump-installation/#findComment-184865 Share on other sites More sharing options...
October 5, 200618 yr Author comment_184886 inside the oil pan ...right? Link to comment https://www.classiczcars.com/forums/topic/21822-oil-pump-installation/#findComment-184886 Share on other sites More sharing options...
October 5, 200618 yr comment_184891 NO. look up at the car you see a thingy above the sway bar with four bolts (12mm head) holding it there. That is the oil pump. i never had much luck lining up the marks on the spindle to put it in. Put the engine at #1 tdc before you change it. Pull dizzy cap and mark where the rotor is. Then pull the oil pump. I use a 8mm bolt with head cut off about 5 inches long as a guide pin put the oil pump in one bolt by hand. check rotor position on the dizzy to see where you are then repeat until back where it was. Link to comment https://www.classiczcars.com/forums/topic/21822-oil-pump-installation/#findComment-184891 Share on other sites More sharing options...
October 6, 200618 yr Author comment_184908 opps....there it is......this looks easer than a small block chevy! Well we will see! thx you guys for the info! Raven Link to comment https://www.classiczcars.com/forums/topic/21822-oil-pump-installation/#findComment-184908 Share on other sites More sharing options...
October 6, 200618 yr comment_184931 I found it easy to mark the position of the rotor on the distributor. Then remove the distributor via the two 10 mm bolts at the base of the distributor. Now you can use a vise grip through the distributor hole to hold up the distributor/oil pump drive. Then you can remove the oil pump without having to worry about getting the distributor timing correct. You don't even have to get the engine to TDC. Link to comment https://www.classiczcars.com/forums/topic/21822-oil-pump-installation/#findComment-184931 Share on other sites More sharing options...
October 6, 200618 yr comment_184934 Am ready to install a new oil pump in my 280Z but my manual does not go into detail but does talk about the dist. and pos #1 TDC but nothing on where the pump is? is the pump under in the oil pan?thx RavenWHY ARE YOU REPLACING THE PUMP ? DID IT IT FAIL ? RARELY DO ONE OF THESE PUMPS FAIL. If you are indicating low pressure , first attach a mechanical gage so you can get a true reading. $15.00 at the parts store . Much easier and a whole lot cheaper than replacing a good pump . If you truly have low pressure , how many miles in the engine ? It may be time for a overhaul . Not flaming here , just trying to keep you from chasing your tail here. Gary Link to comment https://www.classiczcars.com/forums/topic/21822-oil-pump-installation/#findComment-184934 Share on other sites More sharing options...
October 6, 200618 yr comment_184935 Over the years , one thing I have learned is . You CANNOT rely on the stock oil pressure gage ! It mearly is a gage . Like licking your finger and holding it up to see if the wind is blowing. That is all . It indicates some pressure , but what is some ? If you want to know what is happening install a mechanical gage . This will give you the real pressure . Then you can compare the reading on the stock unit and see what it represents. A little up from zero at idle ? What does this account for ? The stock gage is just a gust-a-mation of what is happening . The same for the Temp gage , it is just a indicator . Unless you test it otherwise how do you know how hot the engine really is with the needle in the middle ? Gary Link to comment https://www.classiczcars.com/forums/topic/21822-oil-pump-installation/#findComment-184935 Share on other sites More sharing options...
October 6, 200618 yr comment_184954 good point about the unreliability of the readings for the stock gages. Link to comment https://www.classiczcars.com/forums/topic/21822-oil-pump-installation/#findComment-184954 Share on other sites More sharing options...
October 7, 200618 yr Author comment_185031 thx. I been watching this for a while...I bought the car 2 years ago and had good oil pressure but about 7 months ago the pressure started to drop, Idel at 0 and running at about 45-50 at 60 mph. I did put a mach. gauge in and this is what it ran, I replaced the the sensor, so the only thing i could think of was the pump...I appreciate the info. I just finished replacing the pump and oil pan gasket. I will let you now what happensRaven.... Link to comment https://www.classiczcars.com/forums/topic/21822-oil-pump-installation/#findComment-185031 Share on other sites More sharing options...
October 7, 200618 yr Author comment_185032 oh! I forgot it has 61k on the odometer....Raven Link to comment https://www.classiczcars.com/forums/topic/21822-oil-pump-installation/#findComment-185032 Share on other sites More sharing options...
October 9, 200618 yr Author comment_185166 well it worked! the pump gave life back in the motor.thx for all the help! Link to comment https://www.classiczcars.com/forums/topic/21822-oil-pump-installation/#findComment-185166 Share on other sites More sharing options...
