Posted October 7, 200618 yr comment_185053 Is it possible to change the back up lamp-switch on the transmission case, on an 280 ZXT from 83, without removing the case ? My Hayns manual is not referring to the last models with the newer transmission. It seems that the switch is somewhere on top of the case where you can't see it. Link to comment https://www.classiczcars.com/forums/topic/21843-back-up-lamp-switch/ Share on other sites More sharing options...
October 7, 200618 yr comment_185061 It should be possible. It's difficult to see if your car is on jackstand/ramps. I could see it when my car was on a lift. Link to comment https://www.classiczcars.com/forums/topic/21843-back-up-lamp-switch/#findComment-185061 Share on other sites More sharing options...
October 7, 200618 yr comment_185065 Yes it is easy, the problem is finding a new one. The switch should be on the left side of the transmission. Link to comment https://www.classiczcars.com/forums/topic/21843-back-up-lamp-switch/#findComment-185065 Share on other sites More sharing options...
October 8, 200618 yr Author comment_185111 It should be possible. It's difficult to see if your car is on jackstand/ramps. I could see it when my car was on a lift. I'll see if I can borrow a lift at the garrage. Thanks again! Link to comment https://www.classiczcars.com/forums/topic/21843-back-up-lamp-switch/#findComment-185111 Share on other sites More sharing options...
October 8, 200618 yr Author comment_185112 Yes it is easy, the problem is finding a new one. The switch should be on the left side of the transmission. I didn't look at the left side, because on early models it's on the right side. I'll try to locate it again, and then work on how to get a new one. Thanks again ! Link to comment https://www.classiczcars.com/forums/topic/21843-back-up-lamp-switch/#findComment-185112 Share on other sites More sharing options...
October 8, 200618 yr comment_185124 Actually, my 73 has a 5 speed, and the switch is on the right side. Since Reverse is down and to the right, I'm not sure why the switch would ever be on the left. Link to comment https://www.classiczcars.com/forums/topic/21843-back-up-lamp-switch/#findComment-185124 Share on other sites More sharing options...
October 8, 200618 yr comment_185126 Actually, my 73 has a 5 speed, and the switch is on the right side. Since Reverse is down and to the right, I'm not sure why the switch would ever be on the left.They're talking about a Borg Warner T-5 not a regular Nissan tranny. Link to comment https://www.classiczcars.com/forums/topic/21843-back-up-lamp-switch/#findComment-185126 Share on other sites More sharing options...
October 8, 200618 yr comment_185139 They're talking about a Borg Warner T-5 not a regular Nissan tranny.You are correct the T-5 has the backup switch on the left side and it is different from the standard 4/5 speed switch. Last month when I checked with MSA they couldn't get a new one. Link to comment https://www.classiczcars.com/forums/topic/21843-back-up-lamp-switch/#findComment-185139 Share on other sites More sharing options...
October 8, 200618 yr comment_185142 Wasn't the T-5 also used in Mustangs? If so, could the switch be available from Ford or an aftermarket supplier for Mustang parts? Link to comment https://www.classiczcars.com/forums/topic/21843-back-up-lamp-switch/#findComment-185142 Share on other sites More sharing options...
