Email logins are now active ×
Back up lamp-switch.
Karsten
Is it possible to change the back up lamp-switch on the transmission case, on an 280 ZXT from 83, without removing the case ? :cry: My Hayns manual is not referring to the last models with the newer transmission. It seems that the switch is somewhere on top of the case where you can't see it.
Yes it is easy, the problem is finding a new one. The switch should be on the left side of the transmission.
I didn't look at the left side, because on early models it's on the right side. I'll try to locate it again, and then work on how to get a new one. Thanks again !:)
Actually, my 73 has a 5 speed, and the switch is on the right side. Since Reverse is down and to the right, I'm not sure why the switch would ever be on the left.
They're talking about a Borg Warner T-5 not a regular Nissan tranny.
  • Who's Online   1 Member, 0 Anonymous, 576 Guests (See full list)
