or should I replace it. The grooves aren't real deep, but there are plenty of them, and the "how to rebuild your nissan/datsun ohc engine' book says 'If your fingernail goes bumpety bump, better get a new pump'
https://www.classiczcars.com/forums/topic/21866-is-this-oil-pump-serviceable/
I don't know what would be considered excessive wear or how exactly the oil pump does it's job but it does look like your fingernail would go "bumpity-bump" over those ridges.
Due to the importance of the oil pump and that they're reasonably priced, consider getting a new one to eliminate all doubt.
Good luck with your car.
thanks
I'm actually in the middle of a comlete rebuild, so oil and filter change are the least of my worries.
I was actually agreeing with the 'shot' part. The oil and filter are a no-brainer.
