Posted October 14, 200618 yr comment_185773 I have a early 69-70 240z, I bought what appear to be a good bushinf kit for the shifter that had a little extra play in it. When I took it apart cleaned and inspected, found theirs no way theses parts could be right, My ? is did they come with a diffrent transmission in the very Early models or am I just stupid Link to comment https://www.classiczcars.com/forums/topic/21915-shifter-bushings/ Share on other sites More sharing options...
October 14, 200618 yr comment_185789 The interface of the shift lever with the transmission is very different between the early type "A" transmissions and the later type "B". See the following artivle for more info:http://zhome.com/ZCMnL/tech/AandBtranny.htmI have seen both types of bushings for sale on ebay recently. You might try Courtesy Nissan to see if they have the right ones.www.courtesyparts.com Link to comment https://www.classiczcars.com/forums/topic/21915-shifter-bushings/#findComment-185789 Share on other sites More sharing options...
October 14, 200618 yr comment_185811 If you are not concerned with originality, take a look at this tech tip: http://www.atlanticz.ca/zclub/techtips/shifterbushing/index.html. Link to comment https://www.classiczcars.com/forums/topic/21915-shifter-bushings/#findComment-185811 Share on other sites More sharing options...
