Who has data on tire width fitted to any and all C110 cars, regardless of variant or market?
Related would be track of vehicle.
We know about the 1.3 rule but ....
I have 245/45ZR16 on front and 255/45ZR16 on rear, neither of which comply with the 1.3 rule.
However because I have used 280zx front hubs (they are almost identical to C110) and 280zx rear stub axles (not quite a bolt in but not hard) it appears that I may get away with using the widest tire from the 280ZX as the base size.
Naturally DOT would prefer to have C110 specs as the base so that a precedent isn't set.
So, the ideal is to be able to show that a C110 SOMEWHERE had an optional tyre size at least 195.
Can anyone help?
i can have a look in the parts manuals etc. i have to see if it lists the GT-R track width.. i did read it somewhere too..
Post #2 on this thread might have saved you the bother........
Note to self: Must stop using invisible ink.
Jim, could you also scan & post the whole page?
Transport SA will want 'provenance' (proof of source) to accept the info. They may even demand that I show proof of original source, so if anyone has that info in a Nissan publication please speak up.
Recently Browsing 0
