Posted October 17, 200618 yr comment_186123 Hi all. I'm getting ready to pull a L28 engine out of a 75 280 but the engine does't have the brackets used to connect the hoist chains to the block. I was wondering how I should connect the hoist without these brackets. Thanks Jeff Link to comment https://www.classiczcars.com/forums/topic/21957-pulling-engine/ Share on other sites More sharing options...
October 17, 200618 yr comment_186126 When I yarded the ZX engine out of my '71, it only had the bracket on the front, not on the rear. I borrowed a rear bracket from my other car. Perhaps there's another Z-er in your area who could loan you brackets?Or you could simply bolt the chain to the same bolts/studs/holes that the brackets would use. Link to comment https://www.classiczcars.com/forums/topic/21957-pulling-engine/#findComment-186126 Share on other sites More sharing options...
October 17, 200618 yr comment_186147 Or.......fabricate two 3/16" T x 1" W x approximately 5" long aluminum straps with through holes on each end. This will also keep the chain away from the engine parts. Also, do yourself a favor and use one of those adjustable angle riggs....it will make getting the engine/tranny in or out much easier by allowing you to adjust the angle of dangle!Tom Link to comment https://www.classiczcars.com/forums/topic/21957-pulling-engine/#findComment-186147 Share on other sites More sharing options...
October 17, 200618 yr comment_186149 I took of my head first and then put the head bolts back in the holes and threded the chain around the bolts and it pulled out easy. And I was using a tractor.......... Link to comment https://www.classiczcars.com/forums/topic/21957-pulling-engine/#findComment-186149 Share on other sites More sharing options...
October 17, 200618 yr comment_186150 agemeansnothing said: I took of my head first and then put the head bolts back in the holes and threded the chain around the bolts and it pulled out easy.Did you re-use the head bolts after doing that? Perhaps they'd be just fine but it makes me nervous. Link to comment https://www.classiczcars.com/forums/topic/21957-pulling-engine/#findComment-186150 Share on other sites More sharing options...
October 17, 200618 yr comment_186153 No after that I bought a new set from motorsport. Link to comment https://www.classiczcars.com/forums/topic/21957-pulling-engine/#findComment-186153 Share on other sites More sharing options...
October 18, 200618 yr comment_186182 When pulling a motor from an 80ZX in the JY I jacked a few seatbelts from nearby junkers and tied them to the front hoist point and around the rear of the intake manifold where the EGR pipe is mouted. Worked like a charm the first time pulling the engine, and the second time mounting it on the engine stand. Link to comment https://www.classiczcars.com/forums/topic/21957-pulling-engine/#findComment-186182 Share on other sites More sharing options...
October 18, 200618 yr Author comment_186185 Thanks for the help quys. A guy i know has a 240 with the brackets still on the head so he's going to let me borrow them. Hopefully that will be all I need. Jeff Link to comment https://www.classiczcars.com/forums/topic/21957-pulling-engine/#findComment-186185 Share on other sites More sharing options...
October 18, 200618 yr comment_186186 I removed the brackets on my Z when doing the head gasket swap, and lost them. When I pulled my engine/put it back in, I just ran a length of chain from one engine mount to the other, and then tied a small piece of rope to the water inlet on the back of the head and then to the middle of the chain where the hoist was hooked onto. This worked really well, and was easy to maneuver as well.I live in Sacramento, so if you need some help pulling your engine, let me know and I might be able to lend a hand. Link to comment https://www.classiczcars.com/forums/topic/21957-pulling-engine/#findComment-186186 Share on other sites More sharing options...
October 18, 200618 yr comment_186240 Here's yet another idea...on one of my parts cars I had already sold the head and then needed to pull the rest of the engine and tranny out so....I took a tow chain and threaded it through the slot in the motor mounts around under the block through the slot on the other motor mount back up to the top of the block where I attached both sides of the chain to the engine hoist and out it all came with ease.If that does not make sense please let me know and I'll get a pic and illustrate what I'm talking about. Link to comment https://www.classiczcars.com/forums/topic/21957-pulling-engine/#findComment-186240 Share on other sites More sharing options...
October 18, 200618 yr comment_186245 agemeansnothing said: And I was using a tractor..........Were you using a boom pole on a 3-point hitch? Link to comment https://www.classiczcars.com/forums/topic/21957-pulling-engine/#findComment-186245 Share on other sites More sharing options...
October 19, 200618 yr comment_186263 No I just got the strongest chain the I could buy, wrapped it around all the head bolts and wrapped in around the tractor bucket. Link to comment https://www.classiczcars.com/forums/topic/21957-pulling-engine/#findComment-186263 Share on other sites More sharing options...
