Posted October 21, 200618 yr comment_186504 I need to find a new RH front strut assembly for my '71 and I have found 2.One is marked KYB and has a part# 54302 A2650The other is marked 54302 UO550 Underneath both is Z1 and Japan.Is anyone able to cross reference these part numbers? My CD does not list either part and I "think" the struts may be from a roadster.Thanks for the help in advance!Paul Link to comment https://www.classiczcars.com/forums/topic/21998-kyb-part-number-help/ Share on other sites More sharing options...
October 21, 200618 yr comment_186525 I just replaced my struts with KYBs and the front ones are #361002 they are G-2s Gary Link to comment https://www.classiczcars.com/forums/topic/21998-kyb-part-number-help/#findComment-186525 Share on other sites More sharing options...
October 21, 200618 yr Author comment_186563 Ok,So I said roadster when I meant 1200 or maybe even a 510. Gary, thanks for the reply. Was the KYB number for the insert or was it the full strut housing? I need a full assembly with stub axle. Don't need control arm, ball joints or anything else, just the housing. Thanks,Paul Link to comment https://www.classiczcars.com/forums/topic/21998-kyb-part-number-help/#findComment-186563 Share on other sites More sharing options...
October 22, 200618 yr comment_186620 rxsleeper said: Ok,So I said roadster when I meant 1200 or maybe even a 510. Gary, thanks for the reply. Was the KYB number for the insert or was it the full strut housing? I need a full assembly with stub axle. Don't need control arm, ball joints or anything else, just the housing. Thanks,PaulI must have misunderstood you The KYB numbers are for the strut insert only. Do you have the club's CD that has the part numbers for the complete car ? It has exploded views of the subsystems . It was taken from the Nissan micro fish with Nissan's approval . Gary Link to comment https://www.classiczcars.com/forums/topic/21998-kyb-part-number-help/#findComment-186620 Share on other sites More sharing options...
