Posted October 24, 200618 yr comment_186921 can sone one tell me what this is, and what commodore parts I would need to do this to my 240K ?Nigel Link to comment https://www.classiczcars.com/forums/topic/22040-what-is-swr-rear-vt-commodore-brake-kit/ Share on other sites More sharing options...
October 24, 200618 yr comment_186938 have you tried their websitehttp://www.swmotorsport.com/ Link to comment https://www.classiczcars.com/forums/topic/22040-what-is-swr-rear-vt-commodore-brake-kit/#findComment-186938 Share on other sites More sharing options...
October 24, 200618 yr Author comment_187015 Mr Camouflage said: have you tried their websitehttp://www.swmotorsport.com/Thanks for that, so I take to do this you would need,Brake Disc - Suit Conversion - UndrilledCommodore VT Caliper Rear (Pair)and a built bracket to hold the caliper to the axle housing ?something like that ?I read some where you could do the same type of conversion using R30 real Disc, and calipers ?, is that worth doing ?Nigel Link to comment https://www.classiczcars.com/forums/topic/22040-what-is-swr-rear-vt-commodore-brake-kit/#findComment-187015 Share on other sites More sharing options...
October 25, 200618 yr comment_187153 The R30 setup can be used, but TBH, the pads look a little small for serious braking. I feel there are better options out there.Since there's no caliper that just bolts up, you need to make up a caliper bracket anyway, so why not go for something a bit better.The Series 3 RX7 pads I use in the back of the RX2 (in Fiat calipers) look much bigger and better than the piddly R30 pads, plys Series 3RX7's have vented back discs and share the Datto stud pattern.They may be too deep to fit the 240K rear arm, as I haven't checked it out yet. Otherwise, there are the 2 piston alloy calipers ysed on R32+ skylines (if you have a thing about keeping it Nissan)A little research of a DBA catalogue and a lucas catalogue goes a long way. Link to comment https://www.classiczcars.com/forums/topic/22040-what-is-swr-rear-vt-commodore-brake-kit/#findComment-187153 Share on other sites More sharing options...
October 26, 200618 yr comment_187163 i just got the SWR VT kit fitted on my 240k..http://www.project240k.com/images/displayimage.php?album=12&pos=10it seems very good and very very neat!, however there are very slight clearence issues with the handbrake cable where it goes through the trailing arm (i havn't got to fix it yet). it is also pretty $$$$ (prob over $2500 in the end). obviously (from the pics), the car is not on the road et, so i can't comment on the braking performance... but it should be PRETTY impressiveMy whole braking system now consists of:DR30 1" Master CylinderDR30 10" BoosterR34 GTT Calipers and Disks (296mm)SWR VT/Falcon rear brake kit (with integrated banksia brake)i am selling all the bits i accumulated for a rear DR30 conversion before i went for the SWR kit.. thread is here http://www.classiczcars.com/forums/showthread.php?t=23570 a very good head start on the DR30 conversion! Link to comment https://www.classiczcars.com/forums/topic/22040-what-is-swr-rear-vt-commodore-brake-kit/#findComment-187163 Share on other sites More sharing options...
October 26, 200618 yr comment_187164 a friend of mine who runs a PNE (Paul Newman DR30), is runng R32 GT-R fronts and the stock DR30 rears, he has gone through the mathematics and is totally convinced that the rear DR30's are good enough to match the R32 Gt-r fronts.DR30 brakes are very different to standard R30 brakes however..The DR30 way is a LOT cheaper.. Link to comment https://www.classiczcars.com/forums/topic/22040-what-is-swr-rear-vt-commodore-brake-kit/#findComment-187164 Share on other sites More sharing options...
October 26, 200618 yr comment_187183 that k's going to be flipp'n amazing, kent! btw, are you one of the lads in the pic, or are they members of your fan club? Link to comment https://www.classiczcars.com/forums/topic/22040-what-is-swr-rear-vt-commodore-brake-kit/#findComment-187183 Share on other sites More sharing options...
October 26, 200618 yr comment_187185 i hope so.. i hate to think how much it will cost by the time it finishes! i am afraid i am one of the people.. 240k groupies are hard to find Link to comment https://www.classiczcars.com/forums/topic/22040-what-is-swr-rear-vt-commodore-brake-kit/#findComment-187185 Share on other sites More sharing options...
October 26, 200618 yr Author comment_187186 DR30, were they sold in Australia ?, or Japan.. I'm new to all this skyline stuff, only found out about a year ago, that my 240K was a skyline..:eek: Link to comment https://www.classiczcars.com/forums/topic/22040-what-is-swr-rear-vt-commodore-brake-kit/#findComment-187186 Share on other sites More sharing options...
October 26, 200618 yr comment_187187 I am pretty sure all of them are imported from japan (but maybe some of the PNE's were sold here? i am no authority i am afraid!). there are surprisingly quite a few DR's here though.. very popular in drift circles)from what i gather, the DR's are turbo, independant rear, R200 Differential (some LSD), all disk brakes....I think the local ones (L24's etc.) are R30's with live rear axle, drum brakes etc.. but then the jap MR30's had Idenpendant rears, disks all round. Rear disks wern't as big though as the DR30's, Link to comment https://www.classiczcars.com/forums/topic/22040-what-is-swr-rear-vt-commodore-brake-kit/#findComment-187187 Share on other sites More sharing options...
October 26, 200618 yr comment_187188 it seems that everything nissan post R31 uses integrated banksia brakes within the rear disks (the handbrake assembly), so anything newer will require working hte banksia brake in too.. or you won't have a handbrake (ie. not street legal) R31's could be used, the disks fit on, but you would need to make an adaptor to fit.. but then i don't think the R31 rears are quite up to the DR30 rear's in terms of performance ( i know.. again.. i went and bought all the stuff i needed for R31 conversion, before i bought all the DR30 stuff, before i went the SWR solution... but that was simply because i ran out of time to find a 2nd DR caliper, and HAD to do my rear brakes ) Link to comment https://www.classiczcars.com/forums/topic/22040-what-is-swr-rear-vt-commodore-brake-kit/#findComment-187188 Share on other sites More sharing options...
October 26, 200618 yr comment_187189 this photo probably shows better the binding issue i have..http://www.project240k.com/images/displayimage.php?album=12&pos=16it works now, but will not be good when the handbrake wears a little! Link to comment https://www.classiczcars.com/forums/topic/22040-what-is-swr-rear-vt-commodore-brake-kit/#findComment-187189 Share on other sites More sharing options...
