Posted October 25, 200618 yr comment_187076 Hello, Yes Im new, great forum you have here. Please bear with me, Im half considering an RB25 conversion of a '73 240Z, except I havent bought a Z or an RB25 yet... I see its quite a common swap so there must be plenty of people that can offer some advice. Im wondering if you use the standard Z rear end ? is the standard OEM diff happy with an RB25 pushing power through it ? at what point power wise does it start to moan ? Presumably the standard RB25 gearbox is used mated to a custom/modified prop. Thanks for your help James Link to comment https://www.classiczcars.com/forums/topic/22056-running-gear/ Share on other sites More sharing options...
October 25, 200618 yr comment_187105 James, you'll likely find more answers to these questions at Hybridz.org, where swaps like this are the rule, rather than the exception. Link to comment https://www.classiczcars.com/forums/topic/22056-running-gear/#findComment-187105 Share on other sites More sharing options...
