Posted October 27, 200618 yr comment_187266 Hello zheads....I am replacing a racing tranny I have had in my 240z for 30 years with a 1980 non turbo 5 speed. Purchased a zx clutch slave to match the tranny...also collar, etc... My question is the xz slave cylinder doesn't have adjustment. How do I adjust the pedal play??? Thanks much Link to comment https://www.classiczcars.com/forums/topic/22068-another-zx-tranny-question/ Share on other sites More sharing options...
October 27, 200618 yr comment_187310 Swap the adjustable pin from your original slave onto the new one, reuse the adjustable fork in the new transmission. Or use the non-adjustable fork in the new transmission with the non adjustable pin on the new slave. Either way works, I prefer to have the adjustability.Whats the story on the racing tranny? Is it an old Datsun Comp? Probably worth some coin... Link to comment https://www.classiczcars.com/forums/topic/22068-another-zx-tranny-question/#findComment-187310 Share on other sites More sharing options...
October 28, 200618 yr Author comment_187456 thanks for the reply....the old tranny was one of the first from datsun comp in 1974. close ratio. I traded it for the rebuilt zx tranny. It probably was worth more but was not in very good shape and parts are impossible to find. I did the swap due to extreme noise (whine) in overdrive. It lasted a long time....did hundreds of speed shifts!!! Link to comment https://www.classiczcars.com/forums/topic/22068-another-zx-tranny-question/#findComment-187456 Share on other sites More sharing options...
