Posted October 29, 200618 yr comment_187545 would i get away with bogging up this hole? or does it need welding? its about the diameter of my forefinger Link to comment https://www.classiczcars.com/forums/topic/22106-would-i-get-away-with-bogging-this-up/ Share on other sites More sharing options...
October 29, 200618 yr comment_187563 Rust is like cancer. You must remove all of it or it will come back. If you use bog (bondo) it will look nice for a couple of months, but then it will start to crack and eventually fall off. If you want to fix it right. Remove the taillight and bumper cut out the rusted metal. Fabricate a patch and weld it in place. Paint both sides and you have a permanent fix. Link to comment https://www.classiczcars.com/forums/topic/22106-would-i-get-away-with-bogging-this-up/#findComment-187563 Share on other sites More sharing options...
October 29, 200618 yr Author comment_187597 Thanks mate thats what i was thinking but there is always that side that goes "can i get away with it" Link to comment https://www.classiczcars.com/forums/topic/22106-would-i-get-away-with-bogging-this-up/#findComment-187597 Share on other sites More sharing options...
October 29, 200618 yr comment_187604 Bog as you say , is porous . If it is exposed to the atmosphere it will absorb moisture , the same with primer . So any time you have a hole in a panel and you ''patch '' or fill the hole by pushing bondo through it , you will be inviting moisture to penetrate form the back side and it WILL cause further rust to the panel . Shabby body work done this way and this is the cause for a bad name in it's use , SOME TIMES . When you cut away the rusted metal you most likely well find the troubled area is much larger than you thought . As Ed said rust is like cancer , you must remove it . Gary Link to comment https://www.classiczcars.com/forums/topic/22106-would-i-get-away-with-bogging-this-up/#findComment-187604 Share on other sites More sharing options...
October 30, 200618 yr comment_187624 That is an easy repair to access. I would not even think of not replacing the metal. May need to fair it a bit with bog but, only after removing and replacing the cancer. Link to comment https://www.classiczcars.com/forums/topic/22106-would-i-get-away-with-bogging-this-up/#findComment-187624 Share on other sites More sharing options...
October 30, 200618 yr comment_187628 What the heck is bogging? Link to comment https://www.classiczcars.com/forums/topic/22106-would-i-get-away-with-bogging-this-up/#findComment-187628 Share on other sites More sharing options...
October 30, 200618 yr comment_187629 Mike said: What the heck is bogging?Aussie speak for Bondo. Link to comment https://www.classiczcars.com/forums/topic/22106-would-i-get-away-with-bogging-this-up/#findComment-187629 Share on other sites More sharing options...
October 30, 200618 yr Author comment_187631 why do you call bog bondo? isnt that the name of Ronald Regans chimpazee? Link to comment https://www.classiczcars.com/forums/topic/22106-would-i-get-away-with-bogging-this-up/#findComment-187631 Share on other sites More sharing options...
October 30, 200618 yr Author comment_187632 Mike here we call car putty bog. some other names are slag, spack, filler, and bodgie.we call it bog because it resembles the mud you find in peat bog. I have no idea why its called spack or slag though but they are common names used in panel beater workshops.I dont think i need to say why its called bodgie or dodgie Link to comment https://www.classiczcars.com/forums/topic/22106-would-i-get-away-with-bogging-this-up/#findComment-187632 Share on other sites More sharing options...
October 30, 200618 yr comment_187643 Bondo is a brand name for body filler over here. I think Regan's chimp's name was Bonzo. Link to comment https://www.classiczcars.com/forums/topic/22106-would-i-get-away-with-bogging-this-up/#findComment-187643 Share on other sites More sharing options...
October 30, 200618 yr comment_187668 "Spack" must be derived from the word spackle, which is a filler used for filling seams and imprefections in drywall. Drywall is an interior wall covering for your buildings. I've heard it called gypsum board and wall board as well. Link to comment https://www.classiczcars.com/forums/topic/22106-would-i-get-away-with-bogging-this-up/#findComment-187668 Share on other sites More sharing options...
October 30, 200618 yr comment_187687 I just love the Aussie words. Thanks for the clarification. I need to come see you guys again so I get more practice. One of my aussie buddies told me that I still accentuate my verbs too much. Bugger. Link to comment https://www.classiczcars.com/forums/topic/22106-would-i-get-away-with-bogging-this-up/#findComment-187687 Share on other sites More sharing options...
