We came home from vacation early and that allowed me to finally make time to work on some of the to-do list on my Z. The past two days I was able to: Install the upgraded clock (quartz movement installed in the original clock), rework the dash wiring getting the radio, heater and indicator lights (seat belt, choke) working, install the restored 240Z emblem on the glove box door, install the correct hazard switch label on the dash, raise the center of the dash to allow for correct clearance for the console, install the new leather shift boot, install the restored electric antenna, install the restored luggage straps, and install the new plastic rear interior panel. This completes 80% of my to-do list in just two days. Once I have completed the list it goes to a friend’s body shop (Braun Auto Body,he restores mostly 60's and 70's muscle cars)for fine tuning of the alignment of the doors, hood and rear hatch. It felt good to be able to take the time to work on the Z. I am not letting myself work on the restoration of my recently acquired 72 FJ40 until I complete all of my to-do list on the Z.
  • 1 month later...
Thanks Eugene, I have been working on the to do list. I was able to get the hood adjusted after reading a few post on the subject here. After returning the updated clock to Ron it now is back in and the quarts movement is working perfectly. I am still working on door adjustment, closing hard (any suggestions would be appreciated). Last night, first night cruise in the Z, when I put it back in the garage I noticed that the left front fender emblem had fallen off. I retraced my drive and found the emblem but it had been run over, very disappointing. I am looking for a replacement on ebay.
Hi Jerry,
What kind of door weatherstrip did Ron put on the car? Is it OEM, NOS stock weatherstrip, or aftermarket stock reproduction, or aftermarket with
generic profile?
I found NOS weatherstrip and welting for my car, and after installing, my doors were also hard to close. The composition of this weatherstripping
is a foam rubber type material and will take a SET, eventually. I loosened the door latches very slightly until the doors would close more easily, but
still very tight. I then used something like Armorall, or any other good rubber and vinyl dressing, and liberally soaked all of the rubber weatherstripping.
This not only lubricated the door/weatherstrip interface, but allowed the rubber material to be more supple and I immediately noticed an improvement
in the compression of the weatherstrip.
Although the door will gap a little for a while, if you repeat this process every month or two, tightening the door latches a little each time, you will eventually get the doors back to a flush profile with the body panels and the doors will thud like a Porsche. the warmer the weather, all the better.
If your weatherstrip is an aftermarket stock reproduction, a lot of these have a slightly thicker cross-section profile (sorry, I don't know which aftermarket product is the closest to stock profile) which will exaserbate the problem. If your doors close flush now, but with difficulty, and it is a foam rubber type of material, I think you will find that this will work well for you. I couldn't be happier with my Porsche...uh, 240z door closure thuds.
Let me know if this makes sense to you, Jerry.
Dan
Edited by AZ-240z
Dan,
I sent our a NOS set with the car.:ermm: I will assume that Les used what I sent. I will try your process and see how it works.;) The door is binding on the weather strip at about 1 inch from closed.
Thanks for your advice Dan, I was getting very frustrated with the doors. I just took the car to a local cruise in;) and of course the Z was the only foreign car. I was amazed how the Z was accepted by the non-car owner people at the show. They liked the Z over all of the restored classic american cars and hot rods. I liked the turquoise Hudson myself:love:.
Hope It works for you Jerry. Is the weatherstrip the early style with separate welting, or is it the later style with the welting
and weatherstrip fused together in one piece? To see where it may be binding, sit in the car with a sheet of paper and concentrating
on the front part of the door opening. Place the paper against the weatherstrip, starting maybe at the top of the window frame, and hold
the door closed to the point it starts to bind and see if the paper slips out easily, or if that is the place it is binding. Do this progressively
around the front half of the door,weatherstrip interface until you find where it is binding.
Next, I would make sure that the welting is firmly seating on the body pinch-weld all the way around the door.
I am trying to remember another difference in early and late weatherstripping. I think that the one-piece, welting/weatherstrip combo,
incorporated a flap of rubber that covered the windshield post jamb area. If that is what you have, make sure that the binding
isn't happening in that area. I also recall that this later weatherstrip is a little thicker along the bottom door threshold. I think
that on later zs, the bottom of the door was shaped slightly differently along this threshold area, but I could be wrong, or that
might be a problem area. I believe that this one-piece combo welting/weatherstrip was using after 7/74.
Anyway, Jerry, I am just kind of brainstorming and thinking out loud. If any of this makes sense for things to check, I, again, hope
that my past experiences can be of some use.
When I read what you have done and how you have done it, I feel like I'm looking in a mirror.
Dan
... his wife live in North Carolina, where he is manager of a new Warner Gear plant. Gary and Rita recently attended our oldest sons wedding. When the restoration is complete a trip to North Carolina is at the top of my list. I can’t wait to pull up at Gary and Rita’s house in the Z looking as it did when we met.
hello jerry... great story. i just stumbled upon this thread while at work, and read most of the first page. i'll read more on my own time, but i was wondering if you ever got to make this trip..? best ~ rob.
Rob,
Not yet, maybe this coming summer when I have worked out all of the bugs and completed my reworking of some of Les's work to make the car as good as it can be. Thanks for asking and enjoy the story of my Z. JLP
Rob,
i will indeed. it's a great story... and if either you or gary are ever passing through the raleigh area, and want to visit an early car in dark green just for the sake of reminiscence... z people are always welcome. best ~ r.
Rob, Gary's Z was a 1970 in Green. Sooner or later we will be in the area an will definitely put you on the to stop and see list. Thanks JLP
  • 1 year later...
It has been a while sine I visited this site. The Z is still asleep in it's winter cocoon . I have been working on the restoration of my 1972 Land Cruiser and just completed my first year in my new position at work. Busy times. I will try and update this post in the near future. Hope to get the car ready for this years Z Con. JLP
