Posted November 8, 200618 yr comment_188818 Hey,I am looking for the thing that holds the sunvisors in place. During my restore, I lost mine, I guess. I can not find what it looks like and I do not have a good sence as to what to look for. I have tried ebay, motorsport and my local junk yards.Please help Link to comment https://www.classiczcars.com/forums/topic/22234-rear-view-mirror/ Share on other sites More sharing options...
November 8, 200618 yr comment_188828 Here is the parts list page showing the "holder-sunvisor" as part number 96409-E8700.This is assuming your car is a 73 or earlier. nissanparts.cc shows it is still available for less than $5.ToddPg111-3.pdf Link to comment https://www.classiczcars.com/forums/topic/22234-rear-view-mirror/#findComment-188828 Share on other sites More sharing options...
November 8, 200618 yr comment_188833 Actually, it's the same part number through 78. I've got a spare one somewhere. I'll have to look through my stuff and see if I can find it. Link to comment https://www.classiczcars.com/forums/topic/22234-rear-view-mirror/#findComment-188833 Share on other sites More sharing options...
November 10, 200618 yr Author comment_189098 Thanks Blake,If you have one, I will send you some money for it.Chuck Link to comment https://www.classiczcars.com/forums/topic/22234-rear-view-mirror/#findComment-189098 Share on other sites More sharing options...
November 10, 200618 yr comment_189122 What is your inside Rear View Mirror mounted to?E Link to comment https://www.classiczcars.com/forums/topic/22234-rear-view-mirror/#findComment-189122 Share on other sites More sharing options...
November 11, 200618 yr Author comment_189205 The rear view is mounted directly to the metal on the roof of the car. I am using the 3 screws provided. They are a bit long and the it is a bit loose. Link to comment https://www.classiczcars.com/forums/topic/22234-rear-view-mirror/#findComment-189205 Share on other sites More sharing options...
November 11, 200618 yr comment_189221 The reason I ask, is that the base of the mirror is the same base that accepts the ends on the sun-visors. The mirror itself snaps into the hole for it's clip. This is the safety break-away feature.I'll see if I can find a pic.E Link to comment https://www.classiczcars.com/forums/topic/22234-rear-view-mirror/#findComment-189221 Share on other sites More sharing options...
November 11, 200618 yr comment_189226 The reason I ask, is that the base of the mirror is the same base that accepts the ends on the sun-visors. The mirror itself snaps into the hole for it's clip. This is the safety break-away feature.I'll see if I can find a pic.EThe base of the mirror snaps into a square hole in a metal clip that is in turned covered by the plastic piece that holds the sun visors. The three screws go into the metal piece which actually holds the plastic piece in place. It's possible that the plastic part is broken off and missing but the metal is still there. Link to comment https://www.classiczcars.com/forums/topic/22234-rear-view-mirror/#findComment-189226 Share on other sites More sharing options...
November 11, 200618 yr comment_189233 The base of the mirror snaps into a square hole in a metal clip that is in turned covered by the plastic piece that holds the sun visors. The three screws go into the metal piece which actually holds the plastic piece in place. It's possible that the plastic part is broken off and missing but the metal is still there.This differs from what I have in the 3 - 71, 72 and 73 Z's I have, that's why I'm asking. I don't have that plastic piece you mention. Is this a latter type than the early Z's?The Z's I have access to show that the base is what holds the sun-visor end rod, and it has the square hole for the mirror clip to snap into. No plastic piece. Since the mirror can't be affixed to the roof without the base, and the base has the sun-visor holds, I was wondering why he needed separate pieces.E Link to comment https://www.classiczcars.com/forums/topic/22234-rear-view-mirror/#findComment-189233 Share on other sites More sharing options...
November 11, 200618 yr comment_189240 I don't have that plastic piece you mention. Is this a latter type than the early Z's? I wish I could answer that but it appears that once again I'm a victim of not knowing of production changes to items like this. I'm really only familiar with what's on my 9/71 model. I had no idea that this ever changed. I've attached a picture I just took of mine that clearly shows the separate pieces. As you can see my plastic piece was actually cracked and broken and I used a plastic glue to repair it. I did just attempt to install just the metal piece without the plastic but in that situation the square hole is not deep enough to accept the mirror; the clip on the mirror hits the vinyl. Link to comment https://www.classiczcars.com/forums/topic/22234-rear-view-mirror/#findComment-189240 Share on other sites More sharing options...
November 11, 200618 yr comment_189242 for some reason that looks different than what i have in my car... Link to comment https://www.classiczcars.com/forums/topic/22234-rear-view-mirror/#findComment-189242 Share on other sites More sharing options...
November 12, 200618 yr comment_189268 Mike what you pictured is all I have ever found in a Z-even with a red dot.Will Link to comment https://www.classiczcars.com/forums/topic/22234-rear-view-mirror/#findComment-189268 Share on other sites More sharing options...
