Posted November 10, 200618 yr comment_189096 hey all, got a problem shifting into second gear.. it grinds going in from 1st, or downshifting from 3rd. it always felt like there wasnt enough throw in the hydraulic system to disengauge the clutch fully... well, I pulled the transmission(1981 280ZX 5speed non turbo) to take a look see. and I found that a few of my pressure plate bolts had come loose (I have a centerforce 2 clutch)..about 3-4 turns to snug. It made me think that maybe because of this, my clutch was draging a bit, especially with those centrifical weights.. well, I tightened everything back up, but the transmission back on, replaced the master and slave cylinder, bled the system, I have the right year clutch with collar, and it still does it..although not as bad. It worked fine for the past year or so. This is something that's just happend one day at the track and got worse. It just started grinding one day.. I can get it not grind by pulling out of first, waiting a split second, then go to second, but that could be from the RPMs meshing better. this transmission has been rebuilt before, but I'm starting to question how well.. has anyone had this experience before?? BTW, it doesn't grind at all going into reverse, although before I tore everthing apart it did grind sometimes.also, should the throwout bearing be touching the pressure plate spring at all when the clutch pedal is out?? cause to get this to work, I had to adjust it like that.. which is why i'm thinking the clutch and or plate is bad,let me know if you all need more info.. Link to comment https://www.classiczcars.com/forums/topic/22258-clutch-problems-help-with-diagnosis/ Share on other sites More sharing options...
November 10, 200618 yr comment_189104 Here is what I think happened: once the bolts on the pressure plate backed out, the clutch no longer fully disengaged. This put a lot more load on the syncros when shifting and I'll guess your 2nd gear syncro is now worn (which is usually the first to go). Now that you've fixed your clutch, the problem remains because the syncro is still worn.I think you either rebuild the tranny again, or granny shift. Link to comment https://www.classiczcars.com/forums/topic/22258-clutch-problems-help-with-diagnosis/#findComment-189104 Share on other sites More sharing options...
November 10, 200618 yr Author comment_189106 240ZMan said: Here is what I think happened: once the bolts on the pressure plate backed out, the clutch no longer fully disengaged. This put a lot more load on the syncros when shifting and I'll guess your 2nd gear syncro is now worn (which is usually the first to go). Now that you've fixed your clutch, the problem remains because the syncro is still worn.I think you either rebuild the tranny again, or granny shift.that's kind of what i'm afraid of... well, my friend still has my older 4 speed.. when I get that back.. I think I'll throw it in and see if that doesnt fix the problem... I know that tranny works. and I'd like to be certain before I spend any money. I'm just not looking forward to playing musical transmissions... :hurt: Link to comment https://www.classiczcars.com/forums/topic/22258-clutch-problems-help-with-diagnosis/#findComment-189106 Share on other sites More sharing options...
November 10, 200618 yr comment_189107 Dreco said: 'm just not looking forward to playing musical transmissions... :hurt:If it's any consolation, I bought my 5 speed used, found out the 2nd and 3rd gear syncros were shot, had it rebuilt, put it back in, found out he didn't get it right and syncros still worn, reinstalled, found out he goofed on reverse and it wouldn't stay in gear, pulled it again for repairs, and then finally (touch wood) reinstalled it. By the fourth time I was pretty good at it. :mad: Link to comment https://www.classiczcars.com/forums/topic/22258-clutch-problems-help-with-diagnosis/#findComment-189107 Share on other sites More sharing options...
November 10, 200618 yr comment_189109 When I had a clutch slave go out the symptoms were similar. Started grinding on upshifts, then started having trouble putting it into reverse at all. It was driveable at first and I was thinking about synchros, then on the 3rd day it just blew out entirely and wasn't driveable anymore. You might just check the master and slave by pulling the boots off and see if there is any fluid under the boot. If so, that's your problem. Easy to check, and could be related to the symptoms you're experiencing.You don't want the clutch adjusted out so that the throwout bearing is always in contact with the pp, as this will wear the throwout bearing out rather quickly. Link to comment https://www.classiczcars.com/forums/topic/22258-clutch-problems-help-with-diagnosis/#findComment-189109 Share on other sites More sharing options...
November 10, 200618 yr Author comment_189110 240ZMan said: If it's any consolation, I bought my 5 speed used, found out the 2nd and 3rd gear syncros were shot, had it rebuilt, put it back in, found out he didn't get it right and syncros still worn, reinstalled, found out he goofed on reverse and it wouldn't stay in gear, pulled it again for repairs, and then finally (touch wood) reinstalled it. By the fourth time I was pretty good at it. :mad:oh, I can do it pretty quick now.. I've done this a few times. It takes me longer to get to the drive shaft bolts than it does to take the tranny out now haha... I just hate layin under that tranny and wresling it... Link to comment https://www.classiczcars.com/forums/topic/22258-clutch-problems-help-with-diagnosis/#findComment-189110 Share on other sites More sharing options...
November 10, 200618 yr Author comment_189111 jmortensen said: When I had a clutch slave go out the symptoms were similar. Started grinding on upshifts, then started having trouble putting it into reverse at all. It was driveable at first and I was thinking about synchros, then on the 3rd day it just blew out entirely and wasn't driveable anymore. You might just check the master and slave by pulling the boots off and see if there is any fluid under the boot. If so, that's your problem. Easy to check, and could be related to the symptoms you're experiencing.You don't want the clutch adjusted out so that the throwout bearing is always in contact with the pp, as this will wear the throwout bearing out rather quickly.well, I installed a new master and slave cylinder... I had someone push the clutch while watching the fork.. that part is working fine now, .. it goes into second.. just grinds sometimes.. my gut is telling me tranny.. cause thats the most expensive problem hhahaha Link to comment https://www.classiczcars.com/forums/topic/22258-clutch-problems-help-with-diagnosis/#findComment-189111 Share on other sites More sharing options...
November 10, 200618 yr comment_189112 Dreco said: I just hate layin under that tranny and wresling it...Use your floor jack. Link to comment https://www.classiczcars.com/forums/topic/22258-clutch-problems-help-with-diagnosis/#findComment-189112 Share on other sites More sharing options...
November 10, 200618 yr Author comment_189120 240ZMan said: Use your floor jack.well, it's actually faster not using that.. I had an incedent were it roll off that damn thing and smashed the hell out of my finger...it's still not right haha... I'm 5'10 205lbs and bench 265... I just bench it out of there while wearing a cup hahaha Link to comment https://www.classiczcars.com/forums/topic/22258-clutch-problems-help-with-diagnosis/#findComment-189120 Share on other sites More sharing options...
November 11, 200618 yr comment_189208 Dreco, we met at the ZCON this year, I have the smurf blue turbo 240z, I've rebuilt a couple B boxes like yours, and have my 35'x30' shop nearly completed, I also have an MSA short shifter for a B trans that I'd sell, I'm going to go with an SX trans, as my car has blown up 4 early transmissions over the last few years, if you'd like bring it by and we'll crack it open and see what's what, I live on the NW side of FTW, near 820 and 20Chris, 817-448-9265 Link to comment https://www.classiczcars.com/forums/topic/22258-clutch-problems-help-with-diagnosis/#findComment-189208 Share on other sites More sharing options...
November 12, 200618 yr Author comment_189288 Chris240turbo said: Dreco, we met at the ZCON this year, I have the smurf blue turbo 240z, I've rebuilt a couple B boxes like yours, and have my 35'x30' shop nearly completed, I also have an MSA short shifter for a B trans that I'd sell, I'm going to go with an SX trans, as my car has blown up 4 early transmissions over the last few years, if you'd like bring it by and we'll crack it open and see what's what, I live on the NW side of FTW, near 820 and 20Chris, 817-448-9265 PM sent Link to comment https://www.classiczcars.com/forums/topic/22258-clutch-problems-help-with-diagnosis/#findComment-189288 Share on other sites More sharing options...
November 12, 200618 yr comment_189320 Does anyone have a picture of the tranny all torn apart? What does the syncro look like? Link to comment https://www.classiczcars.com/forums/topic/22258-clutch-problems-help-with-diagnosis/#findComment-189320 Share on other sites More sharing options...
