seems as tho I remember reading a post about someone with a lose and sloppy turn signal, this is what worked for me. I first ran a #31 drill thru the signal mount running it thru with the arm in place, then I ran a 6/48 tapper tap thru the first part thru the arm and most of the way thru the bottom,I do that so it tightens down without compressing the arm so it will move freally.Worked like new when done.You may have to substitute another small tap, size 6/48 are used mostly for gunsmithing
https://www.classiczcars.com/forums/topic/22266-sloppy-turn-signal240z/
