Hi Gang:
If you have a new KYB GR2 shock cartridge for the FRONT of your 240-Z (KYB #361002) - that is not yet installed in your car; could you please extend the piston rod to it's fully extended length. Then measure the distance from the top of the cartridge to the tip of piston rod.
Likewise the rear #361001
Likewise the Tokico's...
Let me know what you find.....
thanks,
Carl B.
Carl,
I have a set of Tokico HPs, the rears are not mounted, the fronts are(but the front suspension isn't) so...
Front HZ3015 8 & 5/8" (not a direct measurement)
Rear HZ3016 8 & 3/8"
Will
Carl;
I know you already received this from me VIA email but posted it here so, it was in one place with the other brands.
KYB
Front # 361002
Over all length 22 5/16"
Piston from housing to shoulder for the threads not to include threads 7 3/8"
Rear # 361001
Over all length 23 15/16"
Piston from housing to shoulder for the threads not to include threads 7 3/16"
Hi Guys:
Thanks for the input.
I was trying to find out if any of the after-market shocks, were significantly longer or shorter in Piston Length, than the OEM Replacement Cartridges. Doesn't look like there is any significant difference.... The OEM Front Shock Piston Length including the treads... is 8 1/4".
FWIW,
Carl B.
