Posted November 13, 200618 yr comment_189423 Hi Gang:If you have a new KYB GR2 shock cartridge for the FRONT of your 240-Z (KYB #361002) - that is not yet installed in your car; could you please extend the piston rod to it's fully extended length. Then measure the distance from the top of the cartridge to the tip of piston rod.Likewise the rear #361001Likewise the Tokico's...Let me know what you find.....thanks,Carl B. Link to comment https://www.classiczcars.com/forums/topic/22297-need-shock-measurements-for-240-zs/ Share on other sites More sharing options...
November 14, 200618 yr Author comment_189545 Bump.... Come on guys - you mean to tell me that no one has new set of shocks laying around that they haven't gotten installed yet !..Carl B Link to comment https://www.classiczcars.com/forums/topic/22297-need-shock-measurements-for-240-zs/#findComment-189545 Share on other sites More sharing options...
November 14, 200618 yr comment_189555 Carl, PM a7dz. I think Jim still has a set of KYBs on his bench. Link to comment https://www.classiczcars.com/forums/topic/22297-need-shock-measurements-for-240-zs/#findComment-189555 Share on other sites More sharing options...
November 14, 200618 yr comment_189574 Carl, I have a set of Tokico HPs, the rears are not mounted, the fronts are(but the front suspension isn't) so...Front HZ3015 8 & 5/8" (not a direct measurement)Rear HZ3016 8 & 3/8"Will Link to comment https://www.classiczcars.com/forums/topic/22297-need-shock-measurements-for-240-zs/#findComment-189574 Share on other sites More sharing options...
November 17, 200618 yr comment_189786 Carl;I know you already received this from me VIA email but posted it here so, it was in one place with the other brands. KYBFront # 361002 Over all length 22 5/16"Piston from housing to shoulder for the threads not to include threads 7 3/8"Rear # 361001Over all length 23 15/16"Piston from housing to shoulder for the threads not to include threads 7 3/16" Link to comment https://www.classiczcars.com/forums/topic/22297-need-shock-measurements-for-240-zs/#findComment-189786 Share on other sites More sharing options...
November 20, 200618 yr Author comment_190078 Hi Guys:Thanks for the input.I was trying to find out if any of the after-market shocks, were significantly longer or shorter in Piston Length, than the OEM Replacement Cartridges. Doesn't look like there is any significant difference.... The OEM Front Shock Piston Length including the treads... is 8 1/4".FWIW,Carl B. Link to comment https://www.classiczcars.com/forums/topic/22297-need-shock-measurements-for-240-zs/#findComment-190078 Share on other sites More sharing options...
